MINIDSP WI-DG Network to USB Interface for miniDSP Alexa Voice Control Black
This accessory adds an additional layer of control for your MiniDSP devices. This interface now allows you to control your MiniDSP hardware via the network (Ethernet or WiFi).
4.5 / 5
Reference : 13321
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 06-10-2026.
WI-DG MiniDSP
WiFi / Ethernet to USB interface
Warning: this device does not work with miniDSP products which are already equiped with network connectivity
Applications are numerous and greatly improves your miniDSP devices' convenience, in a domestic installation, a vehicle or even in the field of home automation. When combined to Alexa Amazon Echo interface, this network interface will indeed offer up a voice control of your miniDSP appliances.
Control your MiniDSP through network
The principle of a DSP is often an additional complexity when installing a sound system. This equipment needs to be programmed with functions that must respond dynamically to your preferences and to the characteristics of your listening environment.
Access to the DSP parameters requires the use of a computer, which forces the user to decide between two options: connect the PC to the DSP, with all the drawbacks it brings speaking in terms of cables and audio elements overflowing the workspace.
The other option is to dedicate an entire computer to the DSP programming, which represents a significant cost and dramatically increases the clutter in your HiFi system.
Wi-DG offers a workaround to the problem by simplifying the second option. It is a small-scale, easy-to-install interface that connects via USB to your miniDSP as if it were a computer. On the other hand it connects to your home network and lets you control your miniDSP anywhere within the same network from any connected device. In other words, you gain a very easy access to the parameters of your DSP while reducing clutter and cable jungles in your sound space as well as your workspace.
Ad Hoc network access
Not only is the Wi-DG able to receive information from the network. It can also work as an transmitter. This represents a major advantage for all situations where it is not physically possible to establish a home network: in a vehicle, or a semi-nomadic system for example.
If no network is available, the USB/network interface Wi-DG is able to create his own wireless Ad Hoc network on which the user can log in to access every feature of the device.
As a last resort, if the computer is not equipped with WiFi connectivity, if your router is unavailable or if your listening room is subject to strong interference, it is always possible to connect the Wi- DG through an RJ45 port. This option will be much appreciated by supporters of wall-through cables.
ALEXA Amazon Support
Wi-DG can go even further thanks to its ability to support signals from Amazon Alexa. When connected to the same network that an Amazon Echo interface, it becomes possible to control your miniDSP device by voice commands.
Automation Integration understands voice commands such as
- Mute / Unmute the device
- Volume up / Volume Down
- Change the presets stored in your MiniDSP memory.
The original configuration requires only a few minutes. Just register your Echo and add the miniDSP Controller pluggin.
TypeWifi / USB interface
Processor580MHz CPU
Wireless standard2.4GHz wireless b / g / n
StandardIEEE® 802.11 b / g / n 2.4GHz
Network Access PointYes
Network connectionYes
Automatic network discoveryYes
USBUSB-2
Power Supply5V (Micro-USB)
Dimensions67.4 x 24 x 74mm
Weight100g
Parts suppliedCAT5 Ethernet Cable - 2m
SUPPORTED DEVICES (IP & NETWORK DISCOVERY)
miniDSP 2x4HD
DDRC-24
miniDSP 2x8 / 8x8 / 4x10 / 10x10
nanoDIGI 2x8
C-DSP 6x8
C-DSP 8x12
miniSHARC Series
nanoSHARC Series
OpenDRC Series
DDRC-22 Series
DDRC-88A / DDRC-88D
nanoAVR HDA / nanoAVR HD
SHD series
Supported devices (Alexa voice control)
SHD series
miniDSP 2x4HD
DDRC-24
nanoDIGI 2x8
C-DSP 6x8
C-DSP 8x12
miniSHARC Series
nanoSHARC Series
OpenDRC Series
DDRC-22 Series
DDRC-88A / DDRC-88D
InputRJ45
OutputUSB
Max sampling rateNC
Transmission / Reception protocolWiFi
Transmission / Reception protocolEthernet
2 reviews
Works also with the MiniDSP app
Nice little product.
Indeed, easy to install an you can get rid of the USB cable.
Works also with the Android or IoS MiniDSP app.
The app lets you select profiles, change volume, mute and turn Dirac Live on or off.
This review has been posted for MINIDSP WI-DG Network to USB Interface for miniDSP Alexa Voice Control Black
Produit pratique
Facile à installer, permet de supprimer du câble lorsqu'on intervient sur son système (mise au point haut parleur par exemple). On peut faire tout ce que l'on fait avec l'application habituelle.
Boîtier très correct solide malheureusement petit donc léger et facilement entraîné par le poids et la raideur des câbles. Peut être je l'integrerai à un appareil.
Je n'utilise pas Alexandre et donc un peu cher pour mon usage.
This accessory adds an additional layer of control for your MiniDSP devices. This interface now allows you to control your MiniDSP hardware via the...
