OYAIDE NRF-005T Noise Suppressor Adhesive Tape Pulshut 4m
Oyaide NRF-005T is a noise suppression tape using PULSHUT® (high performance non-woven textile) material developed by Asahi Kasei Corporation. This is a revolutionary material for suppressing electromagnetic noise and radiation generated by AV equipment and cables, allowing for more transparent sound reproduction.
4.6 / 5
Reference : 17156
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 14-04-2026.
Oyaide NRF-005T
Oyaide NRF-005T Ruban adhésif suppresseur de bruit Pulshut 4m
Oyaide NRF-005T is a noise suppression tape using PULSHUT® (high performance non-woven textile) material developed by Asahi Kasei Corporation. This is a revolutionary material for suppressing electromagnetic noise and radiation generated by AV equipment and cables, allowing for more transparent sound reproduction. It also uses no magnetic elements. With a thickness of only 0.05mm, the NRF-005T offers great flexibility for convenient installation on any surface. It is easy to use, as the NRF-005T is simply snapped onto areas of the audio/video equipment or cable that are likely to produce noise.
Product typeNoise suppressor adhesive tape
MaterialPulshut®
Adhesive surfaceAcrylic
Tape width15mm
Tape thickness~ 0.11mm (base material: 0.05mm + adhesive: 0.06mm)
Density0.8g/cm³
Surface resistance≥ 1.0*10^12Ω/cm
Volume resistivity≥ 1.0*10^12Ω/cm
Tension3.5kgf/cm³
Operating temperature range-20°C / +90°C
Environmental certificationsRoHS
REACH
Sans halogène
Quantity4m
5 reviews
Efficacité indéniable
Plus efficace que les ferrites de filtrage.
This review has been posted for OYAIDE NRF-005T Noise Suppressor Adhesive Tape Pulshut 4m
ETONNANT !
Produit très efficace qui apporte une précision d'écoute indéniable . Attention toutefois à appliquer au fur et à mesure car trop de ce produit à tendance à assécher le son . Après plusieurs essais sur câbles de modulation et secteur , seuls deux rubans ont étaient appliqués sur le premier câble secteur de ma barrette . Ne pas hésiter à tester plusieurs endroits de votre système et à en retirer si besoin . Idéal pour optimiser un système déjà upgradé ; ce sera la touche finale .
Faut juste ne pas en mettre de trop.
Cordons secteur sans blindage? Un pourtour de ce produit cote recepteur et le tour est joue.
utile ou pas ?
Personnellement, je n'ai pas noté d'amélioration concrète ou audible avec ce produit
completely transcendental deductive stuff
i was somehow inspired by a *zoviet-france* picture...highest recommendation if you're into maniac options or prone to sensitive side-effects...i will ask my japanese friends to make an aroma-diffuser version...seriously, it is the most low cost highly adaptable detail (together with the furutech nano liquid)
thanks to audiophonics people for their excellent prestation, as usual
Oyaide NRF-005T is a noise suppression tape using PULSHUT® (high performance non-woven textile) material developed by Asahi Kasei...
