Custom Toroidal Transformer - All Power
Transformateur torique sur mesure - Toutes puissances
4.7 / 5
Reference : 3675
1,00 €tax incl.
0,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
This is a personalised, tailor-made product for which cancellation, modification and retraction are not possible.
Custom toroidal transformer
We offer a service of custom toroidal transformers built according to your needs. There is no minimum order quantity (you can ask for one piece only).
Custom transformers are available in three profiles (standard / low / high) with several types of optional supports.
Our toroidal transformers have a class IP00 protection, class B insulation. They are subjected to a 4kV flash test and comply with ISO9001 TUV CERT.
hi fi toroidal transformer custom specifications primary secondary
Audiophonics custom transformer toroidal electric AC converter hi-fi
Possibilities
Use the tool below to specify the characteristics of your custom toroidal transformer. Price is calculated automatically.
If your toroidal transformer has to meet special requirements or characteristics that lay beyond the capabilities of this calculator, please contact us to request a personalized quote.
Javascript must be enabled to use this tool
How to build your custom transformer :
  • Version 1.24 : Please update your cache (ctrl+F5) to access new options.
    You can now save your custom transformer template in a local file and load it for later use or edit
    - Use the "SAVE TEMPLATE" button to save the file.
    - Use the "CHOOSE FILE" button to load your file.
  • Write the primary voltage of your transformer in the "PRIMARY CIRCUIT" section.
  • Then, input the voltage and max intensity of your first secondary winding in the "SECONDARY CIRCUIT" section.
  • To add a new winding (primary or secondary) click the "NEW WINDING" button in the adequate section. A new line appears. Do not forget to specify the voltage and intensity that you need. "
  • You can remove a winding with the button "REMOVE WINDING". Please note that your transformer must have at least one primary winding and one secondary winding.
  • You can add intermediate cables to a secondary winding. It can be a midpoint (12-0-12V) or a free intermediate cable (0-3-5V). To do this, use the "EDIT" button on the corresponding secondary winding.
  • Caution : a winding cannot have a midpoint and free intermediate cables at the same time. You have to disable one to use the other.
  • Your custom transformer cannot have a unlimited number of cables. Leave the mouse cursor on any button that adds winding, midpoint or cable to know if you are close to those limitations.
  • Once satisfied with your coils, focus on the OPTIONS section. This section allows you to ask for an electrostatic screen, a magnetic screen and a thermal fuse. YOu can also specify the profile of your transformer and request a specific support. The choice of a support is optional and you can leave the default selection if your project does not require special mounting.
  • The "SUMMARY" section provide a summary of the windings values and all the options. Carefully check that the information is correct and complete : it is on this basis alone that your toroidal transformer will be built. If something is not writen here, it will not be a part of the transformer.
  • The Specifications section is given as an indication relative to the power and profile of your transformer. Please note that the proposed values ​​do not include the support and the number of windings which can significantly affect the dimensions & weight.. The more winding and cables, the less precise are those numbers.
  • If something is wrong with the template, the app lists what is wrong under the options section. Until the errors have been solved, it is neither possible to save the template nor to add the transformer to cart.
  • After verifying the summary, choose a quantity and press the add to cart button. Remember, once in the list, the transformer can not be changed. The only way to modify it is to go to your cart, remove the transformer and start again.
Primary voltage (V)N/A
Secondary voltage (V)N/A
Power (VA)N/A
Product customization
After saving your customized product, remember to add it to your cart.
Text
loader
* required fields
58 reviews
Très bon produit, excellent rapport qualité prix
Belle facture, les tensions et courants demandés sont respectés. c'est la deuxième fois que je fais appel à ce service et j'en suis très satisfait.
Raphaël
This review has been posted for Custom Toroidal Transformer - All Power
Transformateur Torique
Livraison plus rapide que prévue , article conforme a la commande , toutes les tensions OK , transfo de qualité , parfait !
Transformateur Torique sur Mesure
Commande reçue largement dans les temps, même avant.
De nombreux échanges ont permis d'avoir des caractéristiques très précises (dimensions, espace restreint) et ont été respectées.
Je recommande fortement, ne pas hésité à contacter le service technique qui est à votre écoute, très satisfait.
transfo pour ampli tubes
commande facile avec le logiciel intégré à la commande , prix et délai correct transfo très bien réalisé .
Très bon produit et très bien réalisé.
Commander pour la réalisation personnelle d'un amplificateur Audio de Sonorisation de ma propre conception de 2X350W sous 8 ohms que ce soit bien clair, je possède des amplis Audio puissant réalisé avec sérieux, le transformateurs sur mesure que ma fournis Audiophonics est parfait ! C'est le moins que l'on puisse dire, il réalisé avec un grand sérieux, les tensions sont stable et correcte d'un enroulement à l'autre je le précise car c'est le principale problème que j'ai pu rencontrer sur des transformateurs d'autres marque pour lesquels j'ai du ajouter du fil rigide par tour aux enroulements pour non seulement avoir les tensions recherchés, mais quelle soit identique d'un enroulement à l'autre, ça se joue à quelques volts, parfois à 1 ou 2 volts mais pour les spécialistes lors d'un test de puissance et au bout de l'amplificateur, cette différence devient importante.
Bref produit de qualité et correctement livré si bien que j'en ai commandé un autre puisque tout ampli audio conçu sérieusement se doit d'avoir ses deux alimentation totalement séparés ;)
