ELECAUDIO LI-07GB IEC C7 Connector Gold Plated 24k 3x5mm² Ø15mm
This IEC C7 Elecaudio LI-07GB connector is ideal for making quality power supply cables. It uses 24k gold plated copper alloy contacts of 5mm², allowing to obtain a very good conductivity and therefore an excellent quality of signal transmission.
4.0 / 5
Reference : 17787
13,90 €tax incl.
11,58 € tax excl.
ELECAUDIO LI-07GB
IEC C7 Connector Gold plated 24k 3x5mm² Ø15mm
ELECAUDIO LI-07GB Connecteur secteur IEC C7 Plaqué Or 24k 3x5mm² Ø15mm
This IEC C7 Elecaudio LI-07GB connector is ideal for making quality power supply cables. It uses 24k gold plated copper alloy contacts of 5mm², allowing to obtain a very good conductivity and therefore an excellent quality of signal transmission. This connector is able to accommodate cables up to 15mm in diameter and is thus suitable for both "classic" cables and HiFi cables with a larger diameter. The connector body is made of PC 94V-0 and TPR. All the screws of this connector are made of stainless steel 304, preventing corrosion.
Connector typeIEC C7
Contact materialCopper alloy
Contact platingGold 24k
Max. cable diameterØ15mm without sleeve
Ø12mm with sleeve
Voltage / Current250V AC / 15A
Body dimensions50 x 30 x 22mm
Dimensions108 x 30 x 22 mm
Weight36g
ScrewsPhillips screws
Material: stainless steel 304
Max cable diameter (mm)15.0
Mounting typeN/A
ConnecticFemale
ConnectorIEC C7
Rated current (A)15.0
4 reviews
A life saver
The availability of good quality C7 connectors for DIY cables is limited. This one is a gift from Elecaudio and Audiophonics at a very affordable price. Bad reviews often come from users who do not have the necessary experience in tightening screws and using tools for such purposes. The connector is reliable, sturdy and without particular difficulty in using it. I tightened the conductors with high force without a problem. Also, all metal parts are non-magnetic. I wish Elecaudio would release this connector in a C5 (Mickey Mouse) version.
This review has been posted for ELECAUDIO LI-07GB IEC C7 Connector Gold Plated 24k 3x5mm² Ø15mm
Un produit bien conçu.
Premier achat de cette prise IEC C7 et très satisfait par sa conception. J'ai monté cette prise sans difficultés sur deux câbles Audiophonics Tornado afin d'upgrader l'alimentation de deux caissons de graves SVS SB1000 PRO. Le résultat n'est probablement pas audible, mais je suis assuré que les caissons reçoivent la quantité de courant nécessaire aux appels de puissance. Merci audiophonics pour la qualités de vos produits et de vos prestations.
Piètre qualité.
Un produit vraiment basse qualité. Btr cassée au premier démontage. direction la poubelle
Sans surprise
Outre une sérieuse qualité de construction, où de l'OFC étamé 1.5 mm2 à gaine silicone recouvert de gaine rilsan y fut aisément installé, le traitement de la commande fut rapide et parfait.
L'alimentation de mon Bluesound Node 2i lui dit merci.
This IEC C7 Elecaudio LI-07GB connector is ideal for making quality power supply cables. It uses 24k gold plated copper alloy contacts of...
