ELECAUDIO LI-23GB IEC C13 Connector Gold Plated 24k 3x5mm² Ø15mm
This IEC C13 Elecaudio LI-23GB connector is ideal for creating quality power supply cables. It uses 24k gold-plated copper alloy contacts of 5mm², which provides a very good conductivity and therefore an excellent quality of signal transmission
4.3 / 5
Reference : 17788
13,90 €tax incl.
11,58 € tax excl.
Shipping date: 07-04-2026.
ELECAUDIO LI-23GB
IEC C13 Connector Gold plated 24k 3x5mm² Ø15mm
ELECAUDIO LI-23GB IEC C13 Connector Gold plated 24k 3x5mm² Ø15mm
This IEC C13 Elecaudio LI-23GB connector is ideal for creating quality power supply cables. It uses 24k gold-plated copper alloy contacts of 5mm², which provides a very good conductivity and therefore an excellent quality of signal transmission. This connector is able to accommodate cables up to 15mm in diameter and is thus suitable for both "classic" cables and HiFi cables with a larger diameter. The connector body is made of PC 94V-0 and TPR. All the screws of this connector are made of stainless steel 304, preventing corrosion.
Connector typeIEC C13
Contact materialCopper alloy
Contact platingGold 24k
Max. cable diameterØ15mm without sleeve
Ø12mm with sleeve
Voltage / Current250V AC / 15A
Dimensions108*22mm
Weight42g
ScrewsPhillips screws
Materrial: Stainless steel 304
Max cable diameter (mm)15.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C13
Rated current (A)15.0
3 reviews
Article de Qualité
Qualité Avérée
This review has been posted for ELECAUDIO LI-23GB IEC C13 Connector Gold Plated 24k 3x5mm² Ø15mm
Good
Not so bad design. Except the m2 screws'print a little bit fragile. Good quality product.
Review
Terrible designe, but sounds good.
This IEC C13 Elecaudio LI-23GB connector is ideal for creating quality power supply cables. It uses 24k gold-plated copper alloy contacts of...
