OYAIDE F1 IEC Plug Beryllium Copper Platinium / Palladium plated Ø17mm
By buying this product you get 33 loyalty points
Reference : 10388
339,90 €tax incl.
283,25 € tax excl.
Shipping date: 27-05-2025.
Branded, this 100% Japanese IEC OYAIDE F1 connector has been designed to offer a high quality and reliability standard for your audio connectivity.
The surface of the F1 body was polished thoroughly twice, then a layer of platinum (0.5 micron) was applied directly to this surface. The polishing is then carried out again 2 times to have a final result without any defects and of superior quality. The last step is an application of Palladium (0.3 micron) plating for its outstanding electrical properties. The combination of these methods of polishing, plating, and the thickness of metallic coatings directly affects the rendering and final sound character. This connector is the best male connector of OYAIDE, part of the range of AC connectors High fidelity.
Oyaide a sélectioeach material to obtain a rugged, elegant and homogeneous connector, reducing vibration and improving the sound quality.
Features:
  • Copper contacts Béyllium (double polishing)
  • Platinum Plating (0.5μ) and then Palladium (0.3μ)
  • Polyacetal POM and Aluminum body machined directly in the mass for optimum rigidity
  • Stainless steel screws
  • Cable diameter: from 6.5 to 17 mm (AWG 10)
  • Voltage / Current Rating: 250V 10A CE
oyade F1
(Example of cable fitted with OYAIDE connectors)
OYAIDE M1e Connecteur Schuko Cuivre
Max cable diameter (mm)17.0
Mounting typeTo screw
ConnecticMale
ConnectorIEC C15
Contacts Material (Connector)Beryllium Copper
Contacts Plating (Connector)Platinum
Contacts Plating (Connector)Palladium
Rated current (A)10.0
