super produit rien à dire cuivre pur plaqué argent rhodium
sans regret prenez la même coté male hyper top 2025 merci
IEC C7 Connector Silver / Rhdoium Plated OFC Copper Ø20mm
The Viborg VF518R IEC C7 power supply connector is of high quality construction, ensuring extremely reliable transmission of the electrical signal. It features pure copper contacts with triple OFC copper, silver and rhodium plating for optimal conductivity. Its robust body is made of nylon and fiberglass. The connector accepts cable diameters up to 19mm with conductors up to 6mm. Mounting is simple with a screw-on system.
| Specifications | |
| Product type | IEC C7 Connector |
| Contacts material | Pure copper |
| Plaquage contacts | OFC Copper Silver Rhodium |
| Mounting type | To screw |
| Compatible cable diameter | Ø6-20mm |
| Max conductors diameter | Ø6mm |
| Voltage / Current | 125V 7A 250V 2.5A |
| General | |
| Dimensions | Ø40 x 62.7mm |
| Color | Silver |
| Max cable diameter (mm) | 20.0 |
| Connectic | Female |
| Connector | IEC C7 |
| Contacts Material (Connector) | Copper |
| Contacts Plating (Connector) | Rhodium |
| Contacts Plating (Connector) | Silver |
| Rated current (A) | 2.5 |
| Rated current (A) | 7.0 |
Average votes 3.5 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Harry m.
A H.
