[GRADE S] ASCILAB C6B Bookshelf Speakers 250W 4 Ohm 85dB Gray + White Waveguide (Pair)
-2%
Refurbished product - Grade S
The AsciLab C6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a 1“ alumina-ceramic dome tweeter with custom waveguide and phase tapping, combined with a 6” woofer with alumina-ceramic cone, all housed in an enclosure with passive radiator.
Reduced price!
Reference : 21546
Refurbished
Limited special offer
1 689,00 €tax incl.
-2%
1 649,00 €tax incl.
1 374,17 € tax excl.
Last items in stock !
Shipping date: 17-03-2026.
Product in perfect condition. Original waveguide modified with a white waveguide (ref. 20937) in our workshop
AsciLab C6BBookshelf Speakers 250W 4 Ohm 85dB Gray + White Waveguide (Pair)
Photo of Ascilab C6B
The AsciLab C6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a 1“ alumina-ceramic dome tweeter with custom waveguide and phase tapping, combined with a 6” woofer with alumina-ceramic cone, all housed in an enclosure with passive radiator. The 5x8" passive radiator provides a considerable boost at low frequencies. Their design allows for lower crossover points and reduced distortion, for an extremely clear sound reproduction. The C6Bs feature a fourth-order crossover at 1.1kHz, optimized via Klippel NFS, and support up to 250W of amplification. They are ideal for demanding audiophile or professional studio use.
AsciLab C6B: Optimized tweeters for controlled sound dispersion
AsciLab C6B tweeters feature a waveguide and internal phase plug designed to precisely manage sound dispersion. These elements avoid phase interference, reduce internal resonance and improve off-axis dispersion. The advantages of this type of configuration translate into a more linear frequency response, reduced distortion and better spatialization of sound, offering a more coherent soundstage.
Zoom in on the C6B tweeter
Zoom in on the C6B woofer
AsciLab C6B: 6" woofer in alumina ceramic
Despite their compact size, the 6" woofers in AsciLab C6B loudspeakers are capable of delivering powerful, well-defined bass in spaces of up to 25m². Alumina ceramics provide exceptional rigidity for faithful, distortion-free reproduction, even at high volume, thanks to a strong limitation of cone deformation at high sound pressure. High-performance and dynamic, these woofers also come with an aesthetically pleasing protective grille, combining performance and design.
AsciLab C6B: A 5x8" passive radiator
AsciLab C6B speakers feature a passive radiator at the rear. This limits unwanted resonance while optimizing low-frequency reproduction. This solution also helps reduce distortion at high volumes, unlike a bass-reflex port, which can generate turbulence. AsciLab has also chosen to integrate a passive radiator in order to maintain a relatively compact speaker design.
C6B passive radiator
Product typePassive speakers
Design2 way
Tweeter1" alumina ceramic dome tweeter
Woofer6" alumina-ceramic woofer with aluminum chassis
DesignWith passive radiator
FinishMate
Crossover frequency1.1kHz
Sensitivity85dB @ 2.83V / 1M
SPL Max. (Full-bandwidth)99dB SPL
SPL Max. (>100Hz)105dB SPL
Frequency response-3dB @ 50Hz / -6dB @ 41Hz
ImpedanceNominal 4 ohm (min 200Hz / 2.6 ohm)
Recommanded amplification50W - 250W
Connection to speaker terminalsBanana 4mm
Bare wires
Forks
Dimensions40 x 20.3 x 26.5cm
Weight8.4kg/speaker
ColorGray
White waveguide
Package1x Pair of AsciLab C6B speakers
(C6B grilles are sold separately)
ColorGray
Impedance (Ω)4
Efficiency / Sensitivity (dB)85.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
Power (W)250.0
Number of ways2
Number of loudspeakers3
Refurbished GradeGrade S
Speaker typePassive
Speaker form factorBookshelf speaker
Refurbished product - Grade S The AsciLab C6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format....
