ELECAUDIO PS-24GC Schuko Type E/F Power Connector 24K 3µ Gold Plated Ø16.5mm Transparent
The Schuko PS-24GC reference plug is distinguished at first glance by its transparent nylon body with impeccable finish and ideal proportions. This chassis can accommodate the most sophisticated cables whose diameter is often incompatible with conventional mains sockets.
4.9 / 5
Reference : 6584
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 03-07-2026.
Elecaudio PS-24GC
Power connector Schuko Gold plated 24k 3µ Ø 16.5mm Crystal
Elecaudio PS-24GC Prise secteur Schuko plaqué or
With an insertion ring limiting the diameter to 16.5mm, supported by a flexible rubber cable clamp that completes the integration, the PS-24GC easily accommodates cables with a large cross-section. All the metal parts, in particular the contact and earth poles, were plated with 24k gold over 3µ thick. This full contact surface plating is stronger and better conductive than standard gold plating and is therefore more resistant.
The internal connection terminals also deserve special attention: Equipped with large fixing screws, and therefore requiring no soldering, they are able to receive large diameter conductors and ensure a firm hold over a particularly large contact surface. Finally, we will appreciate the small diagram directly engraved in the socket, which gives information on the optimal length of cable to strip. Since you are told that nothing has been left to chance...
Connector typeSchuko connector 3 contacts
Connection typeTo screw (BTR screws)
Maximum conductor section16mm² (4.5mm diameter)
PlatingGold 24k 3µ
Maximum cable diameter16.5mm
Voltage / Current250V 16A
Total length89mm
Diameter38mm
ColorTransparent
Max cable diameter (mm)16.5
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)16.0
19 reviews
Aeticle De Qualité
Qualité Avérée
This review has been posted for ELECAUDIO PS-24GC Schuko Type E/F Power Connector 24K 3µ Gold Plated Ø16.5mm Transparent
Top product
Connection good and firm easy to connect solid build gives nice look and small improvement with cable over all sound was deep and bass tight specifically on low volume listening. Nice product for the money. Recommended
Iscott
Très bon produit et facile au montage.
Cordialement
ELECAUDIO PS-24GC Connecteur Secteur Schuko Crystal Or 24K
Une prise secteur Schuko qui présente une alternative intéressante en terme de rapport qualité prix, même si d’autres marques plus coûteuses font un peu mieux notamment au niveau de la fixation des conducteurs.
Sur ce modèle, ladite fixation est assurée au moyen de vis munies d’empreinte de type Allen qui ne permet pas un aussi bon serrage pour les brins de plus grosse section, (vu la petitesse de l’empreinte et sa faible profondeur), qu’une bonne vis cruciforme...
Très bonne prise
Très bonne prise secteur.
Très facile à mettre en œuvre.
Je ne sais pas si cela apporte une meilleure qualité audio mais de sûr les contacts sont très bons.
The Schuko PS-24GC reference plug is distinguished at first glance by its transparent nylon body with impeccable finish and ideal...
