VIBORG VE512S Schuko Type E/F Power Connector Silver Plated Pure Copper Ø20mm
This Viborg VE512S Schuko power connector is of exceptional design quality, using only the highest quality materials to ensure the best possible signal transmission. The contacts are made of pure copper with OFC copper and silver plating for optimal electrical conductivity.
4.6 / 5
Reference : 15917
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 13-05-2025.
Viborg VE512S
Power Connector Schuko Silver Plated Pure Copper Ø20mm
Viborg VE512S Connecteur Secteur Schuko Cuivre Pur Plaqué Argent Ø20mm
This Schuko Viborg VE512S mains connector benefits from exceptional design quality, using only high quality materials to promote the best possible signal transmission. There are thus pure copper contacts with OFC copper and silver plating, ensuring optimal electrical conductivity. The body is made of a sturdy aluminum alloy and Bayer-2805 plastic. The assembly of the cable is done simply, the conductors being fixed using a system to screw. The VE512S accepts cables with a maximum diameter of 20mm and conductors with a diameter of up to 4.5mm.
Product typePower connector
ConnectorMale Schuko
Contacts materialPure copper
Contacts platingOFC Copper
Silver
Body materialAluminum alloy
Bayer-2805 plastic
Max cable diameterØ20mm
Max conductors diameterØ4.5mm
Voltage/Current250VAC 16A
Total dimensions98.6 x 40mm
ColorSilver and transparent
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticMale
ConnectorSchuko
Rated current (A)16.0
5 reviews
Excelentes
Ao longo de muitos anos tenho usado e testado varias marcas de conectores, mas estas Viborg são as melhores, excente qualidade de construção, uma assinatura sónica neutra, com vozes e instrumentos mais reais e naturais, o espectro sonoro é comleto e sem esforço
... escelentes.
This review has been posted for VIBORG VE512S Schuko Type E/F Power Connector Silver Plated Pure Copper Ø20mm
Decent but..
I've used most of the Viborg connector types and would have rated them higher were it not for IeGO connectors which are just a cut above Viborg. Shame Audiophonics don't stock them as they are exceptional after a few months of burn in.
Robust and stylish connector
This connector is very robust with pretty nice buid quality and performs well even with a thicker cable. I have built a few cables with this connector together with 16686, 2059 and 3001. The connection terminals are robust enough to allow thicker cables to be used with secure connections.
These connectors are roomy enough to allow a led illumination being built in (at one's own risk), which looks particularly good with these connectors. I wish these could be a bit cheaper, although they are worth the price.
Excellent connecteur
Remplace un connecteur Iego sur un cable Furutech alfa. Très bien conçue et surtout gain immédiat en musicalité, impression de débouchage du système. Pas d'agressivité. Pour l'alim Farad u streamer. Accuphase E800
Le connecteur VE12SS
J'ai testé depuis une quinzaine d'années au moins une quinzaine de connecteurs Schuko , je classe ce connecteur VIborg champion du monde toutes catégories , le rapport qualité prix et la musicalité sont extraordinaires. Sans autre commentaire !
Charlie
 (3)
This Viborg VE512S Schuko power connector is of exceptional design quality, using only the highest quality materials to ensure the best possible...
