EIZZ EZ-205F Female 3 Poles XLR Connector PTFE Platinum Plated Ø9mm Red (Unit)
This Eizz EZ-205F 3-pin female XLR connector is carefully designed for good signal transmission. Its contacts are made of Copper alloy and Platinum plated. A PTFE insulation considerably limits the impact of interferences on the signal.
Reference : 15091
21,90 €tax incl.
18,25 € tax excl.
Shipping date: 03-03-2026.
EIZZ EZ-205F
EIZZ EZ-205 Connecteur XLR Femelle 3 Pôles PTFE Plaqué Platine Ø9mm Rouge (Unité)
This Eizz EZ-205F 3-pin female XLR connector is carefully designed for good signal transmission. Its contacts are made of Copper alloy and Platinum plated. A PTFE insulation considerably limits the impact of interferences on the signal. The robust body of the connector is made of a chrome-plated aluminum alloy. The connector can accept cables up to 9mm diameter. The assembly is very simple, without soldering, thanks to a screwing system.
EIZZ EZ-205 Connecteur XLR Femelle 3 Pôles PTFE Plaqué Platine Ø9mm Noir (Unité)
Product typeFemale XLR connector
Number of contacts3
Max cable diameterØ9mm
Contacts materialCopper alloy
Contacts platingPlatinum
InsulationPTFE
Body materialChromed Aluminum Alloy
Type of connectionTo screw
Body colorSilver
Marking ring colorRed
Dimensions52.6 x Ø19mm
Insulation materialPTFE
Max cable diameter (mm)9.0
Mounting typeTo screw
ConnecticFemale
Contacts number3
ConnectorXLR
Contacts Plating (Connector)Platinum
This Eizz EZ-205F 3-pin female XLR connector is carefully designed for good signal transmission. Its contacts are made of Copper alloy and Platinum...
