FX-AUDIO D802C PRO Amplifier FDA Bluetooth 5.0 AptX HD NFC Class D STA326 2x80W / 4 Ohm Black
The Pro version for D802C improves Bluetooth module (QCC3034) and a gains a more efficient USB chip CM6422 than its previous model.
This amplifier is a very useful tool that comes standard with a 192kHz 24bit digital to analog converter associated with an S / PDIF interface AKM AK4113, an ADC Wolfson WM88782S and Audio / DSP VIA VT1630A interface.
3.5 / 5
Reference : 12850
149,00 €tax incl.
124,17 € tax excl.
Full-Digital Amplifier Pro D802C
FDA-8Ω 2x50W 24bit / 192kHz STA326 / AK4113 / CM6642
Amp FDA D802CPRO
The PRO version for D802C improves Bluetooth module (QCC3034) and a gains a more efficient USB chip CM6422 than its previous model.
This amplifier is a very comprehensive tool that comes standard with a 192kHz 24bit digital to analog converter associated with an S / PDIF interface AKM AK4113, an ADC Wolfson WM88782S and Audio / DSP VIA VT1630A interface.
An increasingly comprehensive connectivity
connectivity D802C
With its wide range of functionality and highly developed connectivity, the D802C Pro Audio at FX has all the assets to become a sound performance system the keystone.
The D802CPRO said amplifier is a "Full Digital" ie the S / PDIF signal is converted into I2s by AK4113, then directly amplified by a digital audio interface STA326. To do this, it has three digital inputs USB, S / PDIF coaxial and optical Toslink.
This team is also a stereo RCA auxiliary input and a USB audio jack supports OTG. We can connect him an Android smartphone.
Bluetooth 4.2
Chip Bluetooth 4.2
Unlike its predecessor, the PRO model embeds a QCC3034 AptX HD chip. It is therefore compatible with the latest versions of the Bluetooth protocol and works with the 5.0 standard. Wireless connectivity thus gains in performance and speed.
This standard is also less energy, which means that use with a mobile reader (like eg smartphone) consume less battery while ensuring a stable and accurate digital stream.
CM6642 Chip High Speed ​​USB - audio class
CM6642 chip
The control chip / CM6642 conversion can work with resolutions up to 24 bit / 192kHz.
This chip natively supports decoding audio and has interesting specifications codecs for the general sound quality of the device (SNR and THD + N ≥100dB @ 1kHz ≤-85dB ≤0.005%
To facilitate installation, compatibility, and avoid wasting time on the software configuration, this amplifier requires no driver to operate. The USB input is automatically recognized by all devices. Including smartphones also benefit from OTG support.
Control panel and volume knob
volume button and screen
This amplifier offers a neat control interface. There is a power-on button, a select button, a rotary volume control and a backlit control panel ..
For ease and comfort, it can also be controlled remotely via a remote control to a receiver I / R on the front.
Alternatively, the traditional interface is complete enough to let the onscreen user make their own settings with ease. It is even possible to specify an equalizer.
This amplifier emits a slight breath into the speakers during silent passages in the music. Although the phenomenon is very slight, it is still important to take into account when using desktop speakers with close listening.
TypeFull Digital Amplifier
Power Output4Ω: 2x80W
8Ω: 2x50W
Supported sampling rates (max)24bit 192kHz
InputsBluetooth, Auxiliary, Optical, Coaxial, USB
OutputPregnant R + L
Impedance4-8Ω
THD0.09% (± 0.2dB)
SNR92dB
Interface controlRemote control / Control Panel
DC power supply32V 5A (supplied)
Weight1.25kg
Dimensions17.8x11.6x3.5 cm
ViewingDigital display (OLED) - with sample rate
Frequency response18Hz - 22kHz
ClockHigh accuracy
Remote SupportYes (IR) - (supplied without its CR2032 battery, available as accessories)
Audio / DSP controllerVIA VT 1630A
Package1x FX-Audio D802C Pro
1x Remote Controle
1x Power supply
1x USB Cable
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipSTA326
Power (W)50.0
Remote ControlYes
2 reviews
Super produit
j'en ai acheté 4 pour mes enfants après l'avoir testé
This review has been posted for FX-AUDIO D802C PRO Amplifier FDA Bluetooth 5.0 AptX HD NFC Class D STA326 2x80W / 4 Ohm Black
DERIVE DES COMPOSANTS ...
Initialement totalement enthousiasmé par les amplificateurs FDA, j'ai crié "Ô miracle!", en effet j'en possède quatre, de différentes marques. Après quelques mois d'utilisation, la déception a supplanté mon enthousiasme premier, car ces petits FDA évoluent au cours du temps. Lors de mes premières écoutes (ampli neuf) on ne peut qu'être emballé par l'extrême transparence du message musical, la pureté des timbres, la dynamique sans compression... seulement voilà: cela ne dure pas! Après quelques petits mois d'une utilisation modérée il m'a semblé que toutes ces qualités s'émoussaient progressivement. Pour en avoir le coeur net, j'ai acquis un nouveau FX D802 que j'ai rigoureusement comparé à mon "ancien" FX D802 en prenant soin d'utiliser les mêmes câbles, la même alim et bien sûr les mêmes plages musicales. Le constat est sans appel ! après quelques mois, mon ampli n'est effectivement plus du tout le même. Avec le nouveau je retrouve les qualités initiales tant recherchées, avec l'ancien, la dynamique s'est émoussée, les timbres ont perdu en différentiation et la transparence s'est comme évaporée avec son corollaire: une image stéréo qui s'est tassée. Que s'est il passé ? Tout le monde sait que les caractéristiques des composants dérivent au cours du temps (vieillissement des matériaux) ceci généralement au bénéfice des électroniques qui se bonifient musicalement. Pour les FDA ça semble bien être le contraire. Quelle déception et quel regret de m'être débarrassé un peu trop rapidement d'un très bon Creek Evolution 50 ! Comme quoi en matière d'électronique les miracles n'existent pas.
 (6)
 (5)
The Pro version for D802C improves Bluetooth module (QCC3034) and a gains a more efficient USB chip CM6422 than its previous model. This...
