Petit ampli par la taille mais grandes capacités musicales : puissance et clarté.
Hélas la fiabilité n'est pas parfaite, la sortie casque de mon précédent exemplaire n'a tenu qu'un peu plus de deux ans. Juste le temps de la garantie...
The FDA Class D amplifier STA326 DDX Alientek D8, complete controllable via remote control, integrates as standard an analog digital converter PCM5122.
Associated with an S / PDIF interface WM8805 with a jitter of 50ps, an interface USB XMOS on a separate card, this integrated amplifier opens the door to High Definition at a democratic price.
The quality of its components is high-level with a 12dB analog filter at the output of neat amplification featuring film capacitors, armored coils Miden 8A limiting the noise noise on the harmonics.
Analog input capacitors are audiophile quality Elna. The Alientek D8 will also be a desktop companion with headphone amplification MAX9722 in 6.35mm jack capable of "driver" sedentary models with high impedance.
It has three digital inputs (USB, S / PDIF coaxial and Toslink optics).
Its bright, readable OLED display displays in real time the source used as well as the sampling rate of the audio file being played.
This all-in-one amplifier is also equipped with a digital equalizer with many functions (bass, treble, mute etc.) adjustable directly from the remote control.
hewill prove to be the ideal companion for any digital source.
Hisergonomics, sa compacity are notable assets, plus its versatility.
The Alientek D8 amplifier is OTG (USB input) compatible with Android smartphones.
Disconnect speakers and listen to headphones:
To be able to switch off the loudspeaker output by connecting a headset, you must do the following:
" This Alientek D8 amplifier fits perfectly into the line of the new digital amplifiers and we appreciated its sound qualities on speakers, as well as on headphones, and also the possibilities offered by its display, while its many equalizations may prove useful if necessary. "
This amplifier emits a slight breath into the speakers during silent passages in the music. Although the phenomenon is very slight, it is still important to take into account when using desktop speakers with close listening.
When the XMOS driver is installed on Windows 10, it may be necessary to disconnect and reconnect the USB to be detected at startup. The problem does not arise with the default driver included in W10.
Features :
Secondary functions:
Digital and analog inputs:
Dimensions and weight:
Input | Optical |
Input | USB |
Input | SPDIF |
Input | RCA |
Output | Jack 6.35mm |
Output | Speaker terminal |
Color | Silver |
Channel | 2 (Stereo) |
Class | FDA |
Amplifier chip | STA326 |
Power (W) | 80.0 |
Remote Control | Yes |
Average votes 4.1 / 5 17 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Jacques S.
Alexis M.
David H.
Nicolas J.
Emmmanuel D.
