FOUNTEK FW322 Speaker Driver Subwoofer 300W 4 Ohm 90dB 40Hz - 900Hz Ø30.5cm
This Fountek FW322 subwoofer offers a beautiful design quality for deep and accurate bass. With a diameter of 12", it is equipped with a fiberglass cone. Its construction allows it to achieve low distortion and fast response.
Reference : 15372
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 10-06-2026.
Fountek FW322
Fountek FW322 Haut-Parleur Subwoofer 300W 4 Ohm 90dB 40Hz - 900Hz Ø30.5cm
Fountek FW322 Haut-Parleur Subwoofer 300W 4 Ohm 90dB 40Hz - 900Hz Ø30.5cm Fountek FW322 Haut-Parleur Subwoofer 300W 4 Ohm 90dB 40Hz - 900Hz Ø30.5cm
Speaker driver typeSubwoofer
Nominal diameterØ304.8mm (12")
Power handling300W RMS
Impedance4Ω
Frequency response40Hz - 900Hz
Sensitivity90.3dB/W/M
Voice coil diameterØ75mm
Weight7.4kg
Thiele-Small Parameters
Resonant frequency (Fs)41.8Hz
DC Resistance (Re)3.4Ω
Mechanical quality coefficient (Qms)2.213
Electromagnetic quality coefficient (Qes)0.426
Total quality coefficient (Qts)0.357
Compliance equivalent volume (Vas)40.6L
Mechanical compliance of suspension (Cms)0.108mm/N
Force factor (BL)17Tm
Diaphragm mass inc. airload (Mms)133.802g
Max linear excursion (Xmax)±10mm
Surface area of cone (Sd)514.7cm²
Materials
Cone materialFiberglass
Voice coil wire materialCopper
MagnetFerrite
Mounting informations
External diameterØ317mm
Cutout diameterØ284mm
Depth151.5mm
Mounting circle diameter300mm
Number of mounting holes8
Speaker Power (W RMS)300.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)305.0
Diaphragm typeGlass fiber
Efficiency / Sensitivity (dB)90.0
Max Linear Excursion (Xmax) (mm)10.0
Lowest frequency (Hz)40
Highest frequency (Hz)900
This Fountek FW322 subwoofer offers a beautiful design quality for deep and accurate bass. With a diameter of 12", it is equipped with a...
