DDHIFI BC150XLR XLR 4-Pin to 2x Jack 3.5mm Headphone Cable 1.45m
The BC150XLR from ddHiFi is a carefully designed 4-pin XLR to 3.5mm jack headphone cable. Its double-shielded structure effectively protects the signal from electromagnetic interference, and its conductors are made from the best possible materials. The positive signal travels through a set of strands with a total cross-section of 0.258mm², made of pure silver, silver-plated copper and Furukawa copper-silver alloy wires. The negative signal, meanwhile, benefits from pure copper strands with a cross-section of 0.205 mm², and the shielding from silver-plated OFC copper strands with a cross-section of 0.410 mm².
Reference : 20835
139,00 €tax incl.
115,83 € tax excl.
ddHiFi BC150XLR XLR 4-pin to 2x 3.5mm jack headphone cable 1.45m
DDHIFI BC150XLR : Front view
Product typeHeadphone cable
MaterialsPositive signal: Pure silver / Silver-plated copper / Furukawa copper-silver alloy
Negative signal: Pure copper
Shielding: Silver-plated OFC copper
Connectors2x Jack 3.5mm
Terminaison1x XLR 4-pin
Length1.45m
Cross-sectionPositive signal: 0.258mm²
Negative signal: 0.205mm²
Shielding: 0.410mm²
Package1x ddHiFi BC150XLR
Length (m)1.45
ShieldingYes
Section (mm²)0.258
Section (mm²)0.410
Section (mm²)0.205
ConnectorXLR
ConnectorJack 3.5mm
Conductors material (Cable)Copper Alloy
Conductors material (Cable)Silver
The BC150XLR from ddHiFi is a carefully designed 4-pin XLR to 3.5mm jack headphone cable. Its double-shielded structure effectively protects the...
