The BC150XLR from ddHiFi is a carefully designed 4-pin XLR to 3.5mm jack headphone cable. Its double-shielded structure effectively protects the signal from electromagnetic interference, and its conductors are made from the best possible materials. The positive signal travels through a set of strands with a total cross-section of 0.258mm², made of pure silver, silver-plated copper and Furukawa copper-silver alloy wires. The negative signal, meanwhile, benefits from pure copper strands with a cross-section of 0.205 mm², and the shielding from silver-plated OFC copper strands with a cross-section of 0.410 mm².
| Specifications | |
| Product type | Headphone cable |
| Materials | Positive signal: Pure silver / Silver-plated copper / Furukawa copper-silver alloy Negative signal: Pure copper Shielding: Silver-plated OFC copper |
| Connectors | 2x Jack 3.5mm |
| Terminaison | 1x XLR 4-pin |
| Length | 1.45m |
| Cross-section | Positive signal: 0.258mm² Negative signal: 0.205mm² Shielding: 0.410mm² |
| General | |
| Package | 1x ddHiFi BC150XLR |
| Length (m) | 1.45 |
| Shielding | Yes |
| Section (mm²) | 0.205 |
| Section (mm²) | 0.258 |
| Section (mm²) | 0.410 |
| Connector | XLR |
| Connector | Jack 3.5mm |
| Conductors material (Cable) | Copper Alloy |
| Conductors material (Cable) | Silver |
| Conductors Plating (Cable) | Silver |
