The NEOSET Compo systems CARPOWER combine a NEOKICK bass speaker with DT-284 tweeter speaker specially developped and NEOSET filter for a set with an amazing quality of restitution to these dimensions and price range.
These systems have almost everything: extremely small dimensions, complete neodymium magnet, a well-balanced sound behavior thanks to the synthetic laminate membrane low-medium and high speaker with silk membrane. A very precise filter allow for clear and precise sound restitution. The level behavior is well above average. With the 165 system, you can work directly above the high-power subwoofers or in addition to powerful bass, you can also design the set in fullrange. (See the technical data of the NEOKICK-165 and the DT284, the different power and impedance values are due to the combination with the NEOSET filter). Supplied with protective grilles
Impedance | 3 Ω |
Bandwidth | f3-20000 Hz |
Frequency | 2100Hz |
Allowable load | 200 WMAX |
Sound pressure Average (1W / 1m) | 87 dB |
Dimensions | ø 166 mm x 60 mm |
Weight | 1.5kg |
components | NEOKICK-165 DT-284 |
