ifi Audio iPOWER AC-DC Adaptator / Low noise Power supply 15V 1.2A
This high-quality iPower power supply unit has low noise and a large number of DC jack connectors allowing it to provide stable and clean voltage and current at 15V DC 1.2A. It offers an audiophile quality solution in a classic AC adapter. Also available in 5,9, and 12V.
Reference : 12528
49,00 €tax incl.
40,83 € tax excl.
This product has been replaced by the new version iFi Audio iPower MK2.
The iPower is the designated successor of the now-famous Power Adapter Ultra-Low Noise AC / DC Power Adapter, pushing the limits of the power supply and pulling up the entire Ifi Audio range.
Its particularity: Eliminate background noise. (Only 1uV to the Audio Accuracy test 2).
By way of comparison, the old AC adapter delivered a noise of 10uV, and a linear Audiophile lambda delivers on average 20 uV ...
The iPOWER can be used anywhere. It is equipped with 4 adapter allowing you to use it everywhere while traveling abroad.
Features:/ Strong>
  • Input voltage: 100 - 240V AC Li>
  • Output voltage: 15V / 1.2A (Also available in 5V / 2.1A and 9V / 1.5A versions)
  • Output Connectors: 3.5 / 1.35mm, 4 / 1.7mm, 5.5 / 2.1mm, 5.5 / 2.5mm
  • Noise: 1uV
  • Dimensions: 82x43x40mm
  • Weight: 155g
  • Supplied World Adapters
InputType C Main Plug
InputType A Main Plug
InputType G Main Plug
InputType I Main Plug
OutputJack DC 5.5/2.1mm
OutputJack DC 4.0/1.7m
OutputJack DC 5.5/2.5mm
OutputJack DC 3.5/1.35mm
Output voltage (V)15.0
Output current (A)1.2
Input voltage (V)120.0
Input voltage (V)230.0
Power SupplySMPS
2 reviews
Excellente alimentation
Je suis ravi de cette petite alimentation.
Couplée avec un DAC Topping DX3 pro v2, c'est un net gain qui s'est fait ressentir dès les premières écoutes.
Plus de transparence, de douceur et de netteté dans le médium/aigu.
This review has been posted for ifi Audio iPOWER AC-DC Adaptator / Low noise Power supply 15V 1.2A
I used it with a Topping DX3 DAC. It is a very remarkeable sound update! Sounds now much better to real absolute High-End quality.
Best I ever heard on a High-end audio set.
This high-quality iPower power supply unit has low noise and a large number of DC jack connectors allowing it to provide stable and clean voltage...
