Jack DC 12V 3F Supercapacitor Filter
This DC 12V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 5 supercapacitors 20F - 3.0V and an intelligent buffer system with common mode suppression effect. It also incorporates a UTC UZ1085L linear voltage regulator, an STC 8H1K08 microcontroller and a ME85P03 MOSFET transistor.
Reference : 18610
45,90 €tax incl.
38,25 € tax excl.
Shipping date: 18-07-2025.
DC 12V 3F Jack Filter with Supercapacitor to DC Jack
Photo of Jack DC 12V Supercapacitor Filter
This DC 12V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 5 supercapacitors 20F - 3.0V and an intelligent buffer system with common mode suppression effect. It also incorporates a UTC UZ1085L linear voltage regulator, an STC 8H1K08 microcontroller and a ME85P03 MOSFET transistor. Input and output are on DC 5.5/2.1mm jack connectors. LEDs indicate the Jack DC filter loading: 10%, 25%, 50%, 75%, 100%. It is itself powered by 12V 3A via its DC jack input.
Fonctionnement du filtre
When a power supply is connected to the filter input, the 5 LEDs light up cyclically. No voltage is then delivered at the output. The LEDs then light up in the following order: 10% → 25% → 50% → 75% → 100%, as the supercapacitors are charged. To obtain output voltage, it is necessary to reach a charge level of 100%, then press the ON/OFF button. The LED corresponding to the charge level (100%) of the capacitors will then be the only one permanently lit. If the load never reaches 100% with 5 fixed LEDs, and one LED continues to flash, this indicates that your input power supply is not delivering exactly 12V.
Product typeJack DC filter
InputJack DC 5.5/2.1mm
OutputsJack DC 5.5/2.1mm
Total capacitance3F
Dimensions82 x 52mm
ColorArgent
Weight150g
Package1x DC 12V jack filter
1x DC jack cable 5.5/2.1mm to jack 5.5/2.1mm
OutputJack DC 5.5/2.1mm
ColorSilver
Output voltage (V)12.0
Output current (A)NC
Input voltage (V)12.0
Power SupplyPower supply filter
6 reviews
Awesome SQ improvement
I have three of these powering two streamers and a DAC. Give a nice SQ improvement even after dual 5A LT3045 PS regulators. A firm recommendation from me.
This review has been posted for DC 12V 3F Jack Filter with Supercapacitor to DC Jack
Très bon
Mis en aval d'alimentations à découpage stabilisées sur toute la ligne Internet et Ethernet (box-switch-décodeur). Son : augmente la richesse des harmoniques sur toute la plage du médium, son plus "analogique"(Quobuz via Bluesound), toutes proportions gardées à ce que l'on peut ressentir en passant sur un ampli à tubes ; en 5.1 (Netflix) meilleure spatialisation et enveloppement. Image : beaucoup plus nuancée et riche dans les couleurs, exemple : sur une image basique (tv par fibre) raccords de maquillage du présentateur TV nettement perceptibles, films via Netflix : profondeur, réalisme des teintes. Toutefois l'appareil est très léger et j'obtiens un meilleur résultat en l'isolant des vibrations, fixé sur une plaque de bois bitumée.
Surprenant
Une fois branchée entre un Switch Meraki tweaké et une alim linéaire, impossible de l'enlever....c'est plus clair, plus détouré....le gain le plus significatif est sur la lisibilité du grave....fortement recommandé !
excellent
Rien de spectaculaire mais quand même perceptible à ce prix c'est fortement recommandé.
Super RPQ
Filtre secteur efficace, pratique, très abordable et peu encombrant.
Installé entre ma livebox et son adaptateur secteur (12V 2.5 A) , il bonifie très sensiblement la qualité audio du streaming. Meilleure lisibilité (surtout au niveau du grave), meilleure transparence générale...
Merci Audiophonics
This DC 12V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 5...
