Jack DC Supercapacitor Filter 5V
This DC 5V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 4 supercapacitors 20F - 3.0V and an intelligent buffer system with common mode suppression effect. It also incorporates a UTC UZ1085L linear voltage regulator, an STC 8H1K08 microcontroller and a ME85P03 MOSFET transistor.
Reference : 19072
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 16-10-2025.
DC 5V Jack Filter with Supercapacitor to DC Jack
Photo of Jack DC 5V Supercapacitor Filter
This DC 5V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 4 supercapacitors 20F - 3.0V and an intelligent buffer system with common mode suppression effect. It also incorporates a UTC UZ1085L linear voltage regulator, an STC 8H1K08 microcontroller and a ME85P03 MOSFET transistor. Input and output are on DC 5.5/2.1mm jack connectors. LEDs indicate the Jack DC filter loading: 10%, 25%, 50%, 75%, 100%. It is itself powered by 5V 3A via its DC jack input.
Product typeJack DC filter
InputJack DC 5.5/2.1mm
OutputsJack DC 5.5/2.1mm
Dimensions82 x 52mm
ColorArgent
Weight150g
Package1x DC 5V jack filter
1x DC jack cable 5.5/2.1mm to jack 5.5/2.1mm
2x Adapter jack 5.5/2.5mm to jack 5.5/2.1
OutputJack DC 5.5/2.1mm
ColorSilver
Output voltage (V)5.0
Output current (A)NC
Input voltage (V)5.0
Power SupplyPower supply filter
3 reviews
Perfekt
Fungerar perfekt till IFI Zen Dac 3 och Blue 3
Klart fint ljud med djupare bas med Beyerdynamic DT 900 PRO X
This review has been posted for DC 5V Jack Filter with Supercapacitor to Jack DC
Vastly improve Google TV 4K
I added this little thing after a 5v/3A SMPS and a DC2.1 to USB C cable to my Google TV 4K. It greatly improved both the sound and picture. Love it!
Superbe amélioration du résultat Audio
Je connaissais les SC mais j'hésitais de les utiliser a cause de la très forte demande en courant au démarrage, ce "petit" par la taille améliore fortement le résultat audio lorsqu'une alim linéaire ou découpage est utilisée.
J'en possède maintenant 3 dont deux 5 volts sur streamer et Dac la troisième sera utilisée plus tard sur alim du Nas.
N'hésitez pas une seconde le rendu audio passe un gap énorme avec l'ajout de ces super condensateurs.
This DC 5V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 4...
