This LHY Audio BATT-DC regulated linear power supply module uses four 21700 batteries with a capacity of 4900mAh (4.9Ah) and an ultra-low-noise LDO LT3042 linear voltage regulation chip with D45H11 PNP transistor. This linear power supply has a 2-pin GX16 connector output delivering 12V 2A. So you can power your Hi-Fi equipment with an ultra-low-noise signal. The module itself is powered by 16.8V DC on a 5.5/2.1mm DC jack connector. A load protection module completes this input.
Please use the GX16 cable supplied or the Audiophonics references GXDC-21 and GXDC-25 specially designed for LHY Audio power supplies.
1 | GX16 2-pin 12V DC 2A output |
2 | Voltage adjustment +/5%. |
3 | DC 16.8V power supply input on 5.5/2.1mm jack connector |
Product type | Battery-regulated linear power supply |
Input voltage | 16.8V DC |
Voltage and output connectors | 2-pin GX16 connector: 12V DC 2A |
Total output current | 2A |
Battery | 4x 21700 (4900mAh) |
Dimensions | 155 x 100 x 47mm |
Weight | 0.72kg |
Color | Black |
Package | 1x Linear regulated battery power supply LHY AUDIO BATT-DC 1x 2-pin GX16 connector cable to DC jack 5.5/2.1mm 1x EU power adapter 100-240V to 16.8V 2A |
Input | Jack DC 5.5/2.1mm |
Output | GX16 |
Color | Black |
Output voltage (V) | 12.0 |
Output current (A) | 2.0 |
Input voltage (V) | 16.8 |
Power Supply | Regulated Linear Power Supply |
