LHY AUDIO LPS25VA Linear Regulated Power Supply 5V 2A
Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply dedicated to audio, and it will work perfectly with your HiFi devices operating at 5V (DAC, digital source...).
Reference : 19034
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 25-06-2025.
LHY AUDIO LPS25VA Linear Regulated Low Noise Power Supply USB 220V to 5V 2A 25VA
LHY AUDIO LPS25VA Linear Regulated Low Noise Power Supply USB 220V to 5V 3A 25VA : Front view
This power supply includes a Talema transformer coupled with an AOP 177 for even greater voltage stabilization and control. EMI filtering is also included to eliminate interference created by alternating current (AC). Furthermore, a set of three CLC filters positioned at the input and output of the power supply ensure efficient filtering and guarantee a noise-free signal. Last but not least, a bridge rectifier ensures reliable current stabilization, even during prolonged use. The result is a stable output signal with a noise level not exceeding 200uV when used to its full capacity.
The power supply features an aluminum alloy case for efficient heat dissipation, a DC 5.5/2.1mm jack output and a USB-A output. Finally, you can adjust the output voltage on the back of the device by ±0.5V if required.
Input voltage220-240V
Output Voltage / current5V 3A Max
5V 2A Continuous
OutputsJack DC 5.5/2.1mm
USB-A 5V
InputIEC
Case materialAluminium alloy
Dimensions110 x 155 x 63mm
Weight1.114kg
Package1x LHY AUDIO LPS25VA
1x DC 5.5/2.1mm male/male jack cable 80cm
1x power supply cable
InputIEC C14
OutputUSB
OutputJack DC 5.5/2.1mm
Output voltage (V)5.0
Output current (A)2.0
Input voltage (V)220.0
Power SupplyRegulated Linear Power Supply
Parfaite
5 volts parfaitement régulé, ne chauffe absolument pas y compris sur des Super Capa qui réclament largement les 2 ampères au démarrage.
Je possède maintenant deux de ces alim LHY en 5 volts ainsi que d'autres productions LHY qui est un fabricant très recommandable.
This review has been posted for LHY AUDIO LPS25VA Linear Regulated Low Noise Power Supply USB 220V to 5V 2A 25VA
Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are...
