Ultracapacitor Power Supply Filter Module 5-24V DC
This ultracapacitor power filter module enables you to supply a clean 5-24V DC current to power your devices, and supports a maximum current rating of 10A. It is made up of no less than 10 high-quality WIMA supercapacitors.
4.9 / 5
Reference : 18915
42,90 €tax incl.
35,75 € tax excl.
Shipping date: 07-04-2026.
Ultracapacitor Power Supply Filter Module5-24V DC
This ultracapacitor power filter module enables you to supply a clean 5-24V DC current to power your devices, and supports a maximum current rating of 10A. It is made up of no less than 10 high-quality WIMA supercapacitors. This power filter reduces potential interference and noise from your power system. This power filter is ideal for powering a Rapsberry PI, digital interface, NAS, router and more. The module features gold-plated DC5.5/2.1mm input and output connectors, as well as screw terminals with copper contacts for simplified connection when required.
Product typeSupply filter module
Inputs1x DC 5.5/2.1mm jack
1x Screw terminal block
Outputs1x DC 5.5/2.1mm jack
UltracapacitorsWIMA
Operating voltage5-24V DC
Maximum rated current10A
Package1x Ultra-capacitor filter power supply module
Dimensions16 x 5.2 x 2.2cm
Mounting holes spacing14.8 x 4.4cm
InputJack DC 5.5/2.1mm
InputScrew terminals
OutputJack DC 5.5/2.1mm
OutputScrew terminals
ColorN/A
Output voltage (V)5.0
Output voltage (V)24.0
Output current (A)10.0
Input voltage (V)24.0
Input voltage (V)5.0
Power SupplyNC
8 reviews
I thought I had a good filtered DC...
This Filter helps even a Linear Power supply to be better. Well spent money in my system.
This review has been posted for Ultracapacitor Power Supply Filter Module 5-24V DC
Improve router performance
Installed post dual 3A LT3045 PS regulators powering my main wireless router with great results. Improves picture quality and sound quality. A strong recommendation.
Excellent produit
Petit avis rapide.
Ce produit respire la qualité de fabrication.
Après quelques jours d'utilisation, j'obtiens un son plus plein avec des détails supplémentaires . Ce n'est pas le jour et la nuit mais une fois que vous le retirez, il y a bien une différence . Il est donc resté ! Merci encore à audiophonics pour sa rapidité et la qualité de ses emballage .
I didnt expected this quality for this price! Didnt used it yet, but just by holding in hand everything looks great. No cold solder points, connections are straight.
Ottimo risultato
Consigliatissimi.
Usati su alimentatore lineare IAN canada linearpi mk II con uscita a 12 volt per alimentare dac RME adi 2, dac RME adi 2 pro be fe. Per alimentare in 5 volt tramite ian canada linearpi mk II scheda audio usb da pc.
Per alimentare router e switch tramite alimentaotri lineari con lt3045, per alimentae nas con alimentatore lineare da 15 ampere con 5mV di ripple massimo ed ogni volta che sono stati inseriti è migliorata la resa.
Tolti e messi dal Ian canada linerpi mk II han fatto la differenza, anche il altre situazioni.
Portano l'mpianto ad una maggiore risoluzione.
Consigliati anche nel nas, router, switch! Per assurdo posizionati anhe solo li migliorano sia l'audio che il video del pc!
This ultracapacitor power filter module enables you to supply a clean 5-24V DC current to power your devices, and supports a maximum current rating...
