Motor with horn, 100 W MAX, 8 Ω
With standard 35 mm (1 3/8 ") threads, good linearity of the frequency band and high sound pressure for low distortion: a motor suitable for all types of professional applications, combined with a bass-midrange speaker 38 cm (15 ") or in multi-channel systems. The acoustic values mentioned result from the combination of this loudspeaker with the MRH-120. Replacement mobile reel available as optional MRD-120 / VC.
| Specifications Speakers | |
| Impedance (Z) | 8 Ω |
| Resonance frequency (fs) | 1300 Hz |
| Maximum bandwidth | fx-17500 Hz |
| Crowds. cutoff (fmax.) (12dB / oct.) | 3000 Hz |
| Maximum power | 100 WMAX |
| Nominal power (P) | 50 WRMS |
| Pressure sound. (1W / 1m) | 107 dB |
| Angle dispersion (green / sun) | 40 ° / 90 ° |
| Coil diameter | 34.5 mm |
| Magnet diameter | 120 mm |
| cutting | according to flag |
| Mounting depth | according to flag |
| dimensions | Ø 120 mm x 85 mm |
| Weight | 1.8kg |
| Speaker Power (W RMS) | 50.0 |
| Speaker Type | Horn loudspeaker |
| Impedance (Ω) | 8 |
| Loudspeaker diameter (mm) | 25.0 |
| Diaphragm type | N/A |
| Efficiency / Sensitivity (dB) | 100.0 |
| Max Linear Excursion (Xmax) (mm) | N/A |
| Lowest frequency (Hz) | N/A |
| Highest frequency (Hz) | 17500 |
