IEC C20 Socket Silver / Gold Plated Copper Ø4.6mm
The Viborg CI20G is a high quality IEC C20 power supply connector. It uses pure copper contacts with triple plating of OFC copper, silver and 24k gold, ensuring both perfect electrical conductivity and excellent durability. The body of the connector is made of DuPont PA66GF33 polyamide reinforced with glass fiber. The connector accepts conductors up to 4.6mm in diameter. The connector is easily mounted with screws and does not require soldering.
Product type | IEC C20 Socket |
Contacts amterial | Pure copper (purity: 99.998%) |
Contacts material | OFC Copper Silver Gold 24k |
Body material | Fiberglass reinforced DuPont PA66GF33 polyamide |
Max conductors diameter | Ø4.6mm |
Voltage/Current | 250V 16A 125V 20A |
Mounting type | To screw |
Cutout diameter | 36 x 30mm |
Dimensions | 60.5 x 38.95 x 30mm |
Max cable diameter (mm) | 4.6 |
Connectic | Male |
Connector | IEC C20 |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Gold |
Contacts Plating (Connector) | Silver |
Rated current (A) | 16.0 |
Rated current (A) | 20.0 |
