EARACOUSTIC STA-HI END In-Ear Monitors
New
The STA-HI END from EarAcoustic are in-ear earphones based on two dynamic drivers to offer excellent performance at an affordable price. The combination of a 6mm polymer composite driver responsible for the upper part of the frequency spectrum and a 10mm beryllium driver assigned to the lower parts ensures detailed sound reproduction and neutral timbre, making these earphones ideal for professional use or critical listening.
Reference : 20990
46,90 €tax incl.
39,08 € tax excl.
Shipping date: 02-09-2025.
EarAcoustic STA-HI END Dynamic In-Ear Monitors IEM 32 Ohm 110dB 10Hz-30kHz
EarAcoustic STA-HI END : Front view
EarAcoustic STA-HI END: Dual dynamic drivers
The STA-HI END features a dual dynamic speaker architecture, specially designed to cover the entire audio spectrum with maximum clarity and precision.
The first driver, measuring 6 mm in diameter, is dedicated to high-midrange and treble frequencies. It uses a composite polymer cone, chosen for its lightness and rigidity, ensuring excellent transient response and detailed reproduction of upper harmonics.
The second driver, which is larger, has a diameter of 10 mm and incorporates a dual magnetic circuit. Combined with a beryllium-coated diaphragm, this driver delivers powerful, fast and controlled bass and low-midrange reproduction.
EarAcoustic STA-HI END : Dual driver
EarAcoustic STA-HI END: Balanced sound profile
Designed for discerning audiophiles and sound professionals alike, the acoustic profile of the STA-HI END is based on neutrality and transparency. The frequency response is linear, with no excess in the bass or excessive brightness in the treble. This approach preserves signal integrity while ensuring fatigue-free listening, even during long sessions. The result is a natural, balanced sound that is ideal for mixing, production or critical listening.
EarAcoustic STA-HI END : Frequency response curve
EarAcoustic STA-HI END : earphones connected to their cables
EarAcoustic STA-HI END: Silver-plated OFC copper cable
The STA-HI END comes with a 3.5mm jack to 0.78mm 2-pin OFC silver-plated copper CIEM cable, guaranteeing high-quality signal transmission without external interference.
Product typeIn-ear monitors (IEM)
Drivers1x Dynamic driver Ø6mm
1x Dynamic driver Ø10mm
Impedance32Ω
Sensitivity110dB
Frequency response10Hz-30kHz
CableDetachable
Earphone connectors0.78mm 2 pins
Cable terminationJack 3.5mm
Cable materialsSilver-plated OFC copper
Package1x EarAcoustic STA-HI END
1x 3.5mm jack to 0.78mm 2-pin cable
1x Carrying bag
6x Pairs of ear tips
ColorSilver
Impedance (Ω)32
Efficiency / Sensitivity (dB)110
WirelessNo
Phone call featureNo
Noise reductionNo
EARACOUSTIC STA-HI END Dynamic In-Ear Monitors IEM 32 Ohm 110dB 10Hz-30kHz
The STA-HI END from EarAcoustic are in-ear earphones based on two dynamic drivers to offer excellent performance at an affordable price. The...
