LETSHUOER MYSTIC 8 In-Ear Monitors
Letshuoer Mystic 8 in-ear monitors are top-of-the-range IEMs featuring no fewer than 8 Balanced Armature drivers (4 Sonion + 4 Knowles) for detailed, powerful and dynamic sound. This configuration allows each driver to work on a specific frequency band for a precise sound.
By buying this product you get 109 loyalty points
Reference : 20535
1 099,00 €tax incl.
915,83 € tax excl.
Letshuoer Mystic 8 In-Ear Monitors IEM 8xBA 18 Ohm 107dB 20Hz-40kHz
Photo of LETSHUOER Mystic 8
Letshuoer
are top-of-the-range IEMs featuring no fewer than 8 Balanced Armature drivers (4 Sonion + 4 Knowles) for detailed, powerful and dynamic sound. This configuration allows each driver to work on a specific frequency band for a precise sound. Low frequencies are optimized by a low-pass filter module for a punchy, immersive sound. Balanced Armature drivers work in harmony thanks to a 3-way crossover and 4 acoustic tubes. The Letshuoer's low impedance of 18 ohms and high sensitivity of 107dB make them easy to drive. In addition, they feature 0.78mm CIEM connectors and a detachable audiophile cable with balanced 4.4mm jack termination for a high level of compatibility.
LETSHUOER Mystic 8 IEM highlights
Letshuoer Mystic 8: 8-pilot Balanced Armature design
The Letshuoer Mystic 8 features 4 Sonion and 4 Knowles Balanced Armature drivers. Each driver works on a specific frequency range for precise, powerful and dynamic sound reproduction.
LETSHUOER Mystic 8 design
LETSHUOER Mystic 8 low-pass filter
Letshuoer Mystic 8: Punchy, dynamic bass
The Letshuoer Mystic 8 features a low-pass filter module that optimizes bass reproduction. The module is integrated directly into the acoustic tube for precise selection of low frequencies and attenuation of high frequencies, resulting in an impactful, immersive final sound.
Letshuoer Mystic 8: 3-way crossover with 4 acoustic tubes
Letshuoer's Mystic 8 features a 3-way crossover and 4 acoustic tubes for harmonious operation of all Balanced Armature drivers. This configuration ensures smooth, precise sound reproduction while minimizing distortion for a clear, pleasant listening experience.
LETSHUOER Mystic 8 crossover and acoustic tubes
LETSHUOER Mystic 8 cable
Letshuoer Mystic 8: An audiophile detachable cable
To accompany the Mystic 8, Letshuoer has chosen a high-quality detachable cable. This cable is made of 8 silver-plated 20x0.05mm monocrystalline copper conductors and benefits from a layer of shielding. The cable's high-end design ensures optimum signal transmission. In addition, it features 0.78mm CIEM connectors and a balanced 4.4mm jack termination for a high level of compatibility.
Test des LETSHUOER MYSTIC 8 par Headfonia
Letshuoer have made something special here – a specialist IEM for those who value a clean midrange above all. I’d happily recommend getting the Mystic 8 to seasoned listeners who know what they like and what they’re getting into.
logo headfonia
Product typeIn-ear monitors
Drivers4x Sonion Balanced Armature
4x Knowles Balanced Armature
Sensitivity107dB
Frequency response20Hz-40kHz
Impedance18 ohm
Shell materialTitanium alloy
IEM connectorsCIEM 0.78mm
Detachable cable
Cable length1.25m
Conductive cable materialsSilver-plated monocrystalline copper
Cable structure8x20x0.05mm
Cable terminaisonBalanced 4.4mm jack
Package1x Letshuoer Mystic 8
1x CIEM 0.78mm detachable cable to 4.4mm jack termination
9x Pair of in-ear tips
1x Carrying pouch
Impedance (Ω)18
Efficiency / Sensitivity (dB)107
WirelessNo
Cable terminationJack 4.4mm
Phone call featureNo
Noise reductionNo
LETSHUOER MYSTIC 8 In-Ear Monitors IEM 8x Balanced Armature 18 Ohm 107dB 20Hz-40kHz
Letshuoer Mystic 8 in-ear monitors are top-of-the-range IEMs featuring no fewer than 8 Balanced Armature drivers (4 Sonion + 4 Knowles) for...
