MOONDROP MOCA Wireless In-Ear Monitor Grey
With the Moca, Moondrop offers us wireless in-ear monitors equipped with a dynamic 10mm driver with a ceramic and titanium nitride membrane, ensuring a sound experience that is both soft and precise. The Moca headphones feature noise cancellation based on hybrid technology, with particular attention paid to the acoustic duct to avoid wind noise as much as possible. Finally, a real effort has been made to make the user experience as pleasant as possible, whether through automatic detection of earphone wear or wireless recharging of the box.
Reference : 19903
59,90 €tax incl.
49,92 € tax excl.
Last items in stock !
Shipping date: 18-12-2025.
Moondrop Moca Dynamic True Wireless In-Ear Monitor IEM Grey
Moondrop Moca : Front view
Moondrop Moca : Key features
Moondrop Moca: Titanium nitride and ceramic diaphragm driver
Moca in-ear earphones feature a new composite membrane with a titanium nitride and ceramic coating developed by Moondrop's R&D team. The two-stage treatment of the materials that make up the membrane ensures a smooth high-frequency response, superior to that of a metal-coated membrane, as well as ultra-low distortion. The result is a sound full of detail and treble without any granularity or roughness.
This new 10mm driver also features a magnetic circuit made up of N52 magnets and a CCAW Daikaku voice coil, ensuring excellent sensitivity and a wide frequency response while maintaining low distortion.
Moondrop Moca : Cutaway view of the driver
Moondrop Moca : Noise suppression
Moondrop Moca: Hybrid noise suppression
The active noise cancellation of Moca earphones is based on a hybrid FF + FB (Feedforward + Feedback) technology that uses both the surrounding noise and an analysis of the signal emitted to produce a signal with the opposite phase to the unwanted noise detected. This is complemented by an acoustic duct designed to greatly limit the wind noise that could be picked up by the external microphone, completing a noise suppression system that is effective in all circumstances. Furthermore, a transparency mode is also available, so you can listen to your favourite tracks while being aware of your surroundings.
Moondrop Moca: Automatic connection
The charging case has a lid-open detection function, so the earphones automatically reconnect to the paired device as long as the case is open. When the lid is open, a long press on the pairing button at the bottom of the charging case allows new devices to be paired.
Moondrop Moca: Wireless charging
The Moca charging case is compatible with wireless charging. Simply place the side marked with the wireless charging symbol on the charging device (wireless charger not supplied).
Moondrop Moca : Closed charging case
Moondrop Moca : Photosensitive sensor
Moondrop Moca: Photosensitive sensor
Thanks to the compact 10 mm dynamic driver with wide bandwidth and low distortion, the MOCA has enough space to integrate a photosensitive sensor, enabling fine detection of when the earphone is being worn or not. Allowing your music to be paused automatically when you remove the earphones.
Furthermore, if one earphone is removed while noise-cancellation mode is active, the other earphone will automatically switch to transparent mode for a more comfortable user experience.
Moondrop Moca: LC3 codec
Moca earphones also support the LC3 codec (Low Complexity Communications Codec). This is a new-generation codec based on LE Audio technology. It is different from the traditional Bluetooth codec and offers the advantages of high stability, low delay, low power consumption and high sound quality.
Moondrop Moca: VDSF frequency response
Furthermore, Moca has a low latency time for wireless earphones (<55ms) and a frequency response very similar to that of the VDSF model.
Moondrop Moca : Frequency response
Moondrop Moca : MOONDROP Link app
Thanks to the MOONDROP Link application, available on Android and iOS, you can customise a number of features, such as the order in which noise reduction mode and transparency mode are activated, or whether the LC3 codec is used. Furthermore, you can select several frequency response profiles, leaving more or less room for low frequencies.
Product typeTrue Wireless In-Ear Monitor (IEM)
Drivers typeDynamic Ø10mm
Bluetooth version5.4
Supported Bluetooth protocolsSBC / AAC / LC3
Bluetooth working distance10m (barrier-free open environment)
Phone callsYes
Autonomy
Charging portUSB-C / Wireless charging
Earphone charging time1.5h
Case charging time2h
Battery life of earphone6h
Battery life of charging case15h
ColorGrey
Package1x Moondrop Moca
1x Charging case
3x Pairs of silicone eartips (S, M et L)
1x USB-C cable
ColorGray
Impedance (Ω)NC
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessYes
Cable terminationWireless
Headphone / Earphone connectorWireless (Bluetooth)
Phone call featureYes
Noise reductionYes
2 reviews
Bon produit
Écouteurs bluffants compte tenu de leur prix. Son soyeux, aigus jamais agressifs. Pas de fatigue après une longue écoute.Globalement,bien équilibrés.
This review has been posted for MOONDROP MOCA Dynamic True Wireless In-Ear Monitor IEM 20Hz-20kHz Grey
Very solid sound and build quality
It's probably the best buy in this price category. It has very clear and transparent sound and solid build qualility.
Fast and reliable order processing and shipping.
With the Moca, Moondrop offers us wireless in-ear monitors equipped with a dynamic 10mm driver with a ceramic and titanium nitride membrane,...
