By buying this product you get 26 loyalty points
Earphones Triple driver / Double Diaphragme / 18 ohm
The ME500 by Shanling are of superior quality IEM designed to deliver accurate sound reproduction and rich details. From its cable (removable) to internal motors and even its shell, each element has been carefully optimized to provide the highest level of listening experience. The design is intended for good mainten and comfort, allowing for long listening session
The ME500 simultaneously exploit several different IEM driver technologies (hybrid driver). This approach is particularly suited when building high IEMs since it allows to locally use the specific advantages of each technology to overcome the weaknesses inherent in a "simple" building model.
A single earpiece includes a very sophisticated set with a double magnet, OFC coil, diaphragm Nanocomposite and a set of symmetrical frame motors. The first provide generous headroom, low robust and accurate. The engines provide reinforcement for their speed and accuracy doubled in the medium / high medium / high.
Shanling's ME500 embarks very high performance Knowles frame TWFK-30017 drivers. This model is particularly popular for IEM because its level of detail in the mid / trebble without undue "glossyness" or over-sharpness at the top of the spectrum. This promotes an excellent understanding of the signal without causing fatigue listening.
The team of acoustic engineers Knowles has even contributed to the integration of the engine to allow ME500 to use all the qualities of this component.
In addition to the dual Knowles driver, each ME500 includes a proprietary 10mm double driver magnet (> 1 tesla). This component works with a OFC coil and a diaphragm nanocomposite Polyethylene / Polyether ether ketone.
This contributes very significantly to the dynamics (magnetic flux density). This type of driver is distinguished by its excellent energetic efficiency and outstanding transient response, making it a prime candidate for driving dynamics ME500.
The supplied cable has 8 cores each composed of 18 conductors silver-plated OFC. Each core is protected by an individual TPE sheeth before being braided and get excellent strength.
The interconnect cable is equipped with connectors MMCX and may be easily replaced in case of loss or breakage. The other end has a connector 3.5mm gold-plated standard.
The ME500 come with their robust transport metal box, elegant and easy to carry. This accessory makes it easy to take your ME500 when not in use, while providing mechanical protection of all sensitive parts. This significantly increases the life of the headphones.
| Specifications | |
| Type | IEM |
| Engine | Dynamic 10mm owner + Double Frame |
| Connectors | 3.5mm stereo gold-plated |
| Cable | Length: 1.3m Cable: OFC silver plated |
| Impedance | 18Ω |
| Sensitivity | 111 +/- 3dB |
| Frequency response | 20-40 000Hz |
| Weight | 12.5 g |
| Color | Black |
| Impedance (Ω) | 18 |
| Efficiency / Sensitivity (dB) | 111 |
| Lowest frequency (Hz) | 20 |
| Highest frequency (Hz) | 40000 |
| Wireless | No |
| Cable termination | Jack 3.5mm |
| Headphone / Earphone connector | MMCX |
| Phone call feature | No |
| Noise reduction | No |
