SHANLING ME500 PLATINUM In-Ear Monitor IEM Hi Res 18 Ohm Gray
Triple driver earphone with maximum confort and excellent musical restitution. Ideal for use with a mobile  DAP / Mobile preamp.
Reference : 14298
299,00 €tax incl.
249,17 € tax excl.
Shanling ME500 PLATINUM Edition
Earphones Triple driver / Double Diaphragme / 18 ohm
The ME500 by Shanling are of superior quality IEM designed to deliver accurate sound reproduction and rich details. From its cable (removable) to internal motors and even its shell, each element has been carefully optimized to provide the highest level of listening experience. The design is intended for good mainten and comfort, allowing for long listening session
Triple Hybrid driver
The ME500 simultaneously exploit several different IEM driver technologies (hybrid driver). This approach is particularly suited when building high IEMs since it allows to locally use the specific advantages of each technology to overcome the weaknesses inherent in a "simple" building model.
A single earpiece includes a very sophisticated set with a double magnet, OFC coil, diaphragm Nanocomposite and a set of symmetrical frame motors. The first provide generous headroom, low robust and accurate. The engines provide reinforcement for their speed and accuracy doubled in the medium / high medium / high.
Balanced driver KNOWLES
Shanling's ME500 embarks very high performance Knowles frame TWFK-30017 drivers. This model is particularly popular for IEM because its level of detail in the mid / trebble without undue "glossyness" or over-sharpness at the top of the spectrum. This promotes an excellent understanding of the signal without causing fatigue listening.
The team of acoustic engineers Knowles has even contributed to the integration of the engine to allow ME500 to use all the qualities of this component.
Dynamic Driver owner
In addition to the dual Knowles driver, each ME500 includes a proprietary 10mm double driver magnet (> 1 tesla). This component works with a OFC coil and a diaphragm nanocomposite Polyethylene / Polyether ether ketone.
This contributes very significantly to the dynamics (magnetic flux density). This type of driver is distinguished by its excellent energetic efficiency and outstanding transient response, making it a prime candidate for driving dynamics ME500.
PLATINUM version
This is the Platinum version of the IEM Shanling M500. This version uses an octo-core 6N OFC silver-plated conductor instead of a hybrid conductor. This significantly improves the signal finesse while minimizing transmission losses.
Conductor isolation techniques have also been improved with increased protection against oxidation. Changing the PU tube for thermo-retractable PE also offers a better hold on the ear with a softer touch on the skin.
The MMCX connectors now have thicker gold plating than the traditional version, which promotes the connection quality, the lifespan and the mechanical strength of the connector.
High fidelity stereo earphone cable performance silver
Leather carrying case
The ME500 come with a leather carrying case. This elegant and refined accessory makes it easy to take your ME500 when they are not in use, while providing mechanical protection of all sensitive parts. This significantly increases the life of the headphones.
TypeIEM
EngineDynamic 10mm owner
+ Double Frame
Connectors3.5mm stereo gold-plated
CableLength: 1.3m
Cable: octo-core 6N OFC silver plated conductor
Impedance18Ω
Sensitivity111 +/- 3dB
Frequency response20-40 000Hz
Weight12.5 g
Impedance (Ω)18
Efficiency / Sensitivity (dB)111
Lowest frequency (Hz)20
Highest frequency (Hz)40000
