TANCHJIM BUNNY TYPE-C Dynamic In-Ear Monitor
With the Bunny, Tanchjim offers in-ear earphones that are as affordable as they are qualitative. They feature a titanium-plated driver coupled with a double acoustic cavity specially designed to promote low-frequency vibration. The result is a sound reproduction with rich bass and precise highs, offering a wide soundstage.
Reference : 20419
22,90 €tax incl.
19,08 € tax excl.
    Tanchjim Bunny Type-C Dynamic In-Ear Monitor IEM DSP 30Ω 123dB 8Hz-48kHz
    Tanchjim Bunny Type-C : Front view
    Furthermore, the USB-C version of the Bunny also integrates a 24bit DAC, an amplifier stage and a DSP, opening up the possibility of customizing sound rendering thanks to a 5-band equalizer available via the Tanchjin app.
    Tanchjim Bunny Type-C: Dynamic driver
    Tanchjim's Bunny earphones feature dynamic drivers with titanium-plated PET (polyethylene terephthalate) diaphragms and flexible suspension, delivering rich bass, clear vocals and a wide soundstage.
    These drivers are complemented by a double acoustic chamber, offering more precise control over bass and midrange, while providing a harmonic distortion rate of 0.05% at 94dB.
    Tanchjim Bunny Type-C : Driver
    Tanchjim Bunny Type-C : acoustic cavity
    Tanchjim Bunny Type-C: Labyrinth structure of the acoustic cavity
    Bunny earphones benefit from a labyrinth structure of their acoustic cavities, offering even more resonance to low frequencies for deeper, more dynamic sound reproduction.
    Tanchjim Bunny Type-C: Optimized internal cavity
    The Bunny's internal cavity has been developed to minimize high-frequency absorption and sound dispersion, resulting in a clearer, more extended high-frequency response thanks to the improved linearity of the sound waves.
    Tanchjim Bunny Type-C : internal cavity
    Tanchjim Bunny Type-C : earphones and cable
    Tanchjim Bunny Type-C: Silver-plated OFC copper cable
    Bunny is supplied with a silver-plated OFC copper cable to ensure noise-free data transmission. A flexible transparent sheath encloses the cable, making it difficult to entangle.
    Tanchjim Bunny Type-C: DAC and DSP
    The USB-C version of the Bunny also incorporates a two-chip 24bit DAC supporting a sampling rate of up to 96kHz. This version also includes a high-performance operational amplifier, as well as a DSP for furthermore precise control over the final sound output.
    Tanchjim Bunny Type-C :DSP
    Tanchjim Bunny Type-C: 5-band equalizer
    Thanks to the Bunny's built-in DSP, you can use the Tanchjim application available here to shape the sound of your earphones to your taste. To do this, you have access to 4 equalization presets and a 5-band equalizer, with the option of saving and sharing your sound profiles with other users.
    Tanchjim Bunny Type-C: Frequency response
    Tanchjim Bunny Type-C : frequency response
    Product typeIn-ear monitors (IEM)
    Speakers typeDynamic
    Speakers technologieDMT4 Ultra
    DiaphragmTitanium-plated PET (Polyethylene terephthalate)
    Sensibility123dB
    Impedance30Ω
    Total harmonic distortion (THD)0.05% @ 1kHz 94dB
    Frequency response8Hz-48kHz
    Conductor materialSilver-plated OFC copper
    Cable structureLitz wires
    Connector2 pins 0.78mm
    ColorSilver
    Package1x Tanchjim Bunny Type-C
    1x USB-C to 2-pin 0.78mm connector cable
    1x Carrying pouch
    ColorSilver
    Impedance (Ω)30
    Efficiency / Sensitivity (dB)123.0
    Lowest frequency (Hz)8
    Highest frequency (Hz)48000
    WirelessNo
    Cable terminationJack 3.5mm
    Phone call featureNo
    Noise reductionNo
    TANCHJIM BUNNY TYPE-C Dynamic In-Ear Monitor IEM 30 Ohm 123dB 8Hz-48kHz
    With the Bunny, Tanchjim offers in-ear earphones that are as affordable as they are qualitative. They feature a titanium-plated driver coupled with...
