TRUTHEAR NOVA In-Ear Monitors
Truthear's Nova are high-performance in-ear earphones featuring a total of 5 drivers and a waveguide structure made using DLP 3D printing, to deliver sound with a wide frequency response and a smooth, natural timbre.
Reference : 20532
169,00 €tax incl.
140,83 € tax excl.
Truthear Nova In-Ear Monitors IEM Dynamic Balanced Armature 14.8Ω 123dB 8Hz-40kHz
Thuthear Nova : Front view
Truthear
's Nova
Truthear Nova : 5 driver configuration
The Nova uses a total of 5 drivers to cover the entire frequency range effectively. Bass is handled by a Ø10mm dynamic driver with a liquid crystal polymer (LCP) cone and polyurethane suspension. The accompanying magnetic circuit has been specially designed to produce high-performance bass with extremely low distortion.
Thuthear Nova : Dynamic driver
The midrange and upper midrange are handled by a pair of balanced armature drivers specifically selected for their frequency response, perfectly complementing the dynamic driver and the tweeters.
Thuthear Nova : Balanced armature drivers
High frequencies are handled by a pair of balanced armature drivers with sound characteristics similar to those of the SWFK series. This extends the high-frequency response while limiting the Q value so as not to create resonance peaks that are uncomfortable to the ear.
Truthear Nova : Design using DLP 3D printing
The Nova's hybrid acoustic waveguide structure is produced using DLP (Digital Light Processing) 3D printing. This process makes it possible to achieve a level of design finesse that would otherwise be impossible. As a result, Truthear was able to design a waveguide structure tailored to each driver, in order to merge their renderings into a coherent whole, as close as possible to what the brand wished for in terms of sound reproduction.
Thuthear Nova : Diagram of the internal layout of the product
Truthear Nova : Tone profile
The Nova's tone profile has slightly less bass than the HARMAN IE 2019 model and a treble very similar to the HARMAN OE 2013 model. The result is warm, smooth sound reproduction with a clear, natural timbre.
Thuthear Nova : Frequency response curve
Furthermore, Truthear has ensured that despite the Nova's large number of drivers, they all have the same phase across the entire frequency band, so there's no phase distortion to get in the way of the natural sound you're looking for.
Thuthear Nova : Single-crystal pure copper cable
The Nova comes with a 3.5mm jack to CIEM 0.78mm 2-pin single-crystal copper cable for optimum signal transmission, so you can get the most out of your earphones.
Thuthear Nova : Supplied cable terminations
Truthear Nova review by Headfonics
"The TRUTHEAR NOVA checks all the correct tuning boxes for an affordable yet very good IEM. You get a fantastic cable, pouch, extra tips, and a stylish design."
 Headfonics logo
Product typeIn-ear monitors (IEM)
Speakers1x Dynamic driver
4x Balanced armature drivers
Dynamic driver diaphragmØ10mm liquid crystal polymer (LCP)
Impedance14.8Ω ±15% @ 1kHz
Sensitivity123dB/Vrms @ 1kHz
Total harmonic distortion (THD)≤1% @ 1KHz (94dB)
Frequency response8Hz - 40kHz
CableDetachable
Earphone connectorsCIEM 0.78mm 2 pins
Cable terminationJack 3.5mm
Cable materialsSingle-crystal copper
ColorBlue
Package1x Truthear Nova
1x 3.5mm jack to CIEM 0.78mm 2-pin cable
1x Carrying pouch
6x Pairs of ear-tips
ColorBlue
Impedance (Ω)14.8
Efficiency / Sensitivity (dB)123.0
WirelessNo
Phone call featureNo
Noise reductionNo
Qualité prix incroyable
Ces IEM possèdent un rapport qualité-prix vraiment intéressant.
Au niveau des + :
- Voix très détaillées (on entends les "twisting" de la langue et des lèvres)
- Séparation des instruments intéressante
- Basses propres et pas trop étouffées
Les - :
- Un dac me semble obligatoire, surtout pour les passages percutants (Les refrains semblent "plats")
- Les morceaux Classiques sont plus agréable sans Dolby Atmos, avec une préférence au Lossless (les enregistrements de Lang Lang - Pianiste - sont plus détaillés sans Atmos; la pression sur les notes et la tuile qui frappe le bois se remarque plus facilement sans DA)
- Manque de spatialisation
This review has been posted for TRUTHEAR NOVA In-Ear Monitors IEM Dynamic Balanced Armature 14.8 Ohm 123dB 8Hz-40kHz
Truthear's Nova are high-performance in-ear earphones featuring a total of 5 drivers and a waveguide structure made using DLP 3D printing, to...
