1MII LAVAUDIO B08+ Class D Amplifier TPA3116 Bluetooth 5.0 ATS2853 2x50W / 4 Ohm
The 1Mii B08+ is an affordable and powerful amplifier with integrated Bluetooth receiver. Integrating an ATS 2853 chip, it benefits from Bluetooth 5.0 reception with support for AAC and SBCI transmission codecs.
Reference : 17489
89,00 €tax incl.
74,17 € tax excl.
1Mii B08+
Class D amplifier Bluetooth 5.0 receiver ACC SBCI ATS2853 2x50W
1MII B08+ Class D Amplifier Bluetooth 5.0 Receiver AAC SBCI QCC3034 2x50W / 4 Ohm
The 1Mii B08+ is an affordable and powerful amplifier with integrated Bluetooth receiver. Integrating an ATS 2853 chip, it benefits from Bluetooth 5.0 reception with support for AAC and SBCI transmission codecs. Equipped with antennas, it allows long distance transmission, up to 30m without obstacle. A Stereo RCA input is also available.
Its amplification stage allows it to develop a power of 2x50W, ideal for accompanying small passive bookshelf speakers.
On the output connector side, there are of course speaker terminals.
The front of the device has three buttons, allowing you to adjust the volume level, but also to adjust the bass and treble levels.
Powerful chips
The amplifier has a TPA3116D chip, allowing an output power of 2x50W, moreover, the ATS2853 Bluetooth chip supports AAC, SBCi codecs.
Tecnical characteristics
Product typeBluetooth Amplifier
ImputsBluetooth 5.0
1x RCA stereo
Outputs1x Speakers terminal
Bluetooth version5.0
Suported Bluetooth profilesA2DP
AVRCP
HFP
Suported Bluetooth codecsACC
SBC
Max transmission distancewith out obstacle : 30m
Output power2x 50W / 4 Ohm
Operating temperature range-10°C / +45°C
THD0.5% ≤
SNR≤ 98db
Response frequency20Hz - 20kHz
Supply voltageDC 12- 24V 4A
Dimensions136 x 101 x 45mm
Weight418g
Package1x 1Mii B08+
1x Power supply 24V 4A
OutputSpeaker terminal
DAC / ADC ChipNC
Max sampling rateNC
Channel2.1
Amplifier chipN/A
Power (W)50.0
The 1Mii B08+ is an affordable and powerful amplifier with integrated Bluetooth receiver. Integrating an ATS 2853 chip, it benefits from Bluetooth...
