AUDIO-GD MASTER 10 MK2 Balanced Amplifier ACSS 2x 500W 4 Ohm
AUDIO-GD MASTER-10 MK2 Class A Balanced Amplifier ACSS 2x 500W 4 Ohm
The Audio-GD Master 10 MK2 is an impressive Symmetrical Amplifier in Class A, capable of delivering great power to accompany the most demanding speakers.
By buying this product you get 299 loyalty points
Reference : 15541
2 999,00 €tax incl.
2 499,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
Integrated amplifier / Balanced ACSS
Audio-GD MASTER-10
MK2 Edition
Linear Fidelity & Non Negative Feedback
For this MK2 Edition of its Master 10, Audio-GD has updated its Class A amplifier to offer even better audio measurements. The brand integrates Linear Fidelity technology to the output circuits and Non Negative Feedback to the amplifier in general. This particular design allows to obtain a linear response curve as well as a very low level of distortion, for a sound reproduction of a very great transparency and this whatever the output level and the reproduced frequency.
An integrated amplifier of great power
Audio-GD presents us once again the quintessence of technology in audio with this Master 10 MK2 amplifier with a more than neat and clean architecture.
The famous brand of high fidelity audio offers us here an amplifier in the most accomplished form possible with outstanding performances: it delivers 2x 250W under 8 Ohm or 2x 500W under 4 Ohm.
Each product of the brand is scrupulously tested with one of the most powerful systems in the world: the Audio Analysers 2700 Series from Audio Precision.
Uncluttered, extraordinarily efficient connectivity
The Master 10 MK2 has 5 analog inputs: 2x RCA / 2x XLR / 1x ACSS. The output is of course on 2 speaker terminals, where you just have to plug your speakers to enjoy.
The result is unmistakable: great musicality, thanks to exceptional dynamics and a rich sound that is extremely detailed in every way. We can tell you that you're approaching - if not reaching - perfection with this HiFi device.
Arrière Audio-GD MASTER-10
An outstanding amplifier
Balanced / R-Core / ACSS / Integrated
This Master 10 MK2 is equipped with no less than 4 transformers including 2 R-Core for a total of 1500W, 140.000uF of very high end capacitors, and 24 very high performance ON Semiconductor transistors for the output stage.
This amplifier is also designed around a purely symmetrical discrete ACSS circuit, with a separate power supply to avoid any interference or electromagnetic disturbances on the signal.
The volume control is also optimized, having 4 channels and 99 steps, digitally controlled by relays to avoid any channel balance problem and improve the sound quality.
Audio-GD Master-10 MK2 Amplificateur Class A Symétrique ACSS 2x500W 4 Ohm
ACSS
ACSS
Audio-GD has its own signature technology called ACSS for "Audio-GD Current System Signal". Thanks to the expertise and know-how of the firm, this technology offers a sound less colored, more detailed, and of a neutrality without equivalent..
Each technical engineer of the brand is, in addition to being experienced, a HiFi and Audio enthusiast like you and us. To know, when the ACSS output is used, the XLR and RCA outputs are switched to MUTE.
Class A
An amplifier has the particularity of having all its active components always in conduction. They fully amplify the input signal, thus limiting the harmonic distortion on the output signal. The output signal of the Master 10 MK2 is therefore of excellent quality, due to the absence of this famous sinusoidal crossing distortion. Its gain and preamplifier stages operate in Class A, using discrete components, without any PDO or coupling capacitor in the signal path.
Class A
Shielding & Anti-vibration system
The Master 10 MK2 uses a solid Aluminum alloy chassis to prevent transformer eddy currents from interfering with the audio circuits. Thus, the internal design of the Master 10 MK2 is separated into two sections by aluminum plates. The Ac power cable is also shielded.
Vibrations are also taken into account in order to promote the best possible sound reproduction. Each gain channel is placed under a 5mm thick aluminum plate, which allows both to dissipate heat efficiently but also to avoid vibrations.
Product typeAmplifier
Inputs2x Balanced stereo XLR
2x Single-ended stereo RCA
1x Balanced stereo ACSS
OutputsSpeaker terminals
Output power2x 250W @ 8 Ohm
2x 500W @ 4 Ohm
2x 1000W @ 2 Ohm
SNR> 115dB
Input sensitivity1.2V RMS @ XLR
2mA RMS @ ACSS
Frequency response20Hz - 20kHz (0.01dB)
Input impedance94kOhm @ XLR
< 10 Ohm @ ACSS
Crosstalk> -120dB
Consumption150W
Supply voltage220-240V AC 50/60Hz
WeightApprox. 40kg
Housing materialAluminum
Dimensions480 x 440 x 190mm
Package1x Audio-GD Master 10 MK2
1x Power cable
1x Metal remote control
InputACSS
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipN/A
Power (W)500.0
Mieux qu'un tube
Ces années j'ai eu plusieurs amplis tubes et puis j'ai voulu tester cet ampli suite à des commentaires que je lisait sur les forums.
Il sonne comme je l'imaginais dans ma tête et c'est encore une prouesse de notre ami Kimwa d'Audio Gd.
Pour faire simple, voici une réponse que j'ai adressée à un membre du Forum qui me posait une question.
Je n'ai pas pu comparer avec me MK1 car ces amplis ne sont pas écoutables en magasin...mais je suppose que ce doit être mieux, sinon à quoi ça sert de rajouter l'alimentation régénératrice.
En tous cas, maintenant qu'il commence à être un peu mieux rodé, cet ampli est tout simplement magnifique.
Transparent comme un un tube, profondeur et dynamique , les timbres sont justes de l’extrême grave aux aigus les plus scintillants, mais sans agressivité.
Et puis cette énorme réserve de puissance qui le rend vivant, même à faible volume.
je retrouve même des micros détails que je n'entendait pas, même avec le tube.
Bref, trouver à ce prix un ampli transistor qui sonne aussi bien voire mieux qu'un tube...et aussi bien que des amplis transistor 10 fois plus chers (et que j'ai écoutés) c'est inespéré.
Configuration:
Qobuz Hi Res
Audirvana en mode NOS et sortie KERNEL
Interface Audio GD DI20 sortie I2S et horloges couplées en mode parallele avec le Dac
Dac AUDIO GD R8 en mode NOS et sortie ACSS vers ampli
Ampli AUDIO GD master 10 MK2
Enceintes TANNOY précision 6.4
This review has been posted for AUDIO-GD MASTER 10 MK2 Balanced Amplifier ACSS 2x 500W 4 Ohm
The Audio-GD Master 10 MK2 is an impressive Symmetrical Amplifier in Class A, capable of delivering great power to accompany the most demanding...
