Bonne qualité de son. En achetant des enceintes d'occasion, ça remplace avantageusement une enceinte connectée pour éccouter de la musique avec un smartphone, une tablette ou un PC.
This product has been replaced by the new version, the BT60W PRO Amplifier MA12070.
Bluetooth 5.0 Amplifier 2x50W
Audiophonics presents an alternative version of the very popular BT60V2 amplifier. It gives up its volume control and instead integrates a simple, efficient and preconfigured DSP processor. This version supports Bluetooth EDR (enhanced data rate) to take advantage from a more stable and less energy-consuming data flow when used as a bluetooth wireless receiver.
It is designed to work as a bluetooth amplifier and can also work with any audio source with volume control such as a smartphone through its jack 3.5mm input.
Now equipped with two 50W TPA3116D2 amplifier modules, the BT60DSP will offer you a significant boost of power, ideal for use with a computer, tablet or smartphone as input.
To adapt to your needs in terms of connections, the BT60DSP offers a jack 3.5mm input.
You do not want to be constrained by the use of cables and want to stream your music from your sofa? It comes with a Bluetooth 5.0 controller!
As for the audio output, a terminal block allows you to connect the amplifier to your speakers. Finally, the power plug is now placed on the back, much more convenient for wiring.
Designed around a chassis made of black anodized aluminum and white plastic, it is both extremely compact but also very elegant. It can be easily integrated into an audio system or on your desktop.
| Connections: Inputs | |
| 3.5mm Jack | x1 |
| Bluetooth 5.0 | Yes |
| Terminal Blocks | - |
| Specifications | |
| Amplifier Modules | 2x TPA3116D2 |
| Power | 2x50W (4Ω) |
| Bluetooth range | 15m |
| Switch | On / Off |
| Power Supply | 12V 5A via Jack DC 5.5 / 2.5mm (included) - Accepts a voltage from 9 to 24V |
| Miscellaneous | |
| Chassis material | Black anodized aluminum and white plastic |
| Dimensions | 78 x 70 x 23mm |
| Weight | 118g |
| Package | |
| 3.5mm Male to RCA Stereo Male to Male Cable | 1x |
| 3.5mm Male to 3.5mm Jack Cable | x1 |
| Power supply adapter 12V 5A | x1 |
| Notice | x1 |
| Input | Jack 3.5mm |
| Input | Bluetooth |
| Output | Speaker terminal |
| Color | Black |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | TPA3116D2 |
| Power (W) | 50.0 |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Christian C.
Franck S.
