AURALIC Polaris All in one Wireless Streaming Amplifier 2x120W / 8 Ohm
The integrated DAC wireless WIFI POLARIS amplifier defines the AURALiC brand: Innovative technology, high resolution and musical sound, an efficient user interface
By buying this product you get 329 loyalty points
Reference : 11420
3 299,00 €tax incl.
2 749,17 € tax excl.
Auralic polaris wireless AmplifierThe integrated DAC wireless WIFI POLARIS amplifier defines the AURALiC brand: Innovative technology, high resolution and musical sound, an efficient user interface. The AuraliC Polaris is a wireless streamer, a music server, a DAC, a pre-amplifier and a stereo power amplifier.
This is the ultimate solution for music lovers looking for high quality streaming from a single compact audio component.
Foldable to all configurations, the Polaris has seven inputs including digital and analog audio Streaming sources.
A very high level digital design:
The AURALiC POLARIS benefits from all the Bit Perfect technologies of these elders and in particular the digital filter "Flexible Mode Filter" which, unlike conventional filters (SHARP, FAST and SLOW), benefits from a natural rhythmic capacity (little pre and post echo ) close to the NOS converters without their noise defects and loss of resolution in the acute medium. Furthermorethis integrated features Femto Master Clock with a very high resolution supporting Quad-Rate DSD and PCM up to 32Bit / 384K. These clocks are supplied by a 9V power supply separate from the rest of the electronic circuit.
A stable and high-power Pre-amp and amplifier section:
The powerful Class D internal stereo amplifier module can provide 120 watts per channel at 8 ohms, 180 watts per channel at 4 ohms continuous power with exceptionally low distortion for the most demanding speakers. The pre-amplifier part incorporates a new technology combining digital volume and analog pre-amplification for the best of both worlds. Thus the pre-amplifier section of the Polaris is dynamic, transparent, precise without dynamic settlement or sound scene, even at low volume.
Interface AURALiC Polaris Lightning DS compatible Roon:
POLARIS uses the award-winning Streaming interface AURALiC Lightning DS compatible Open Home, UPnP. The R & D team provides regular automatic updates with new features that further improve the user interface. Another novelty, this DAC amplifier integrates Roon Audio digital audio library management for an ever-changing musical experience.
Specifications AURALiC Polaris:
Technical characteristics :
  • Amplifier Power: 120W / 180W (8ohm / 4ohm)
  • Frequency Response: 20 - 20KHz, +/- 0.5dB
  • Total Distortion Rate: <0.01%, 20Hz-20KHz @ 1W
  • Inter-modulation: <0.01%, 20Hz-20KHz @ 1W
Entries Streaming:
Network File Reader by RJ 45 Input
USB inputs for external hard drive and USB stick
Internal Capacity: HDD 1TB 2.5 "Integration Capability (not supplied)
Server Capacity: uPnP / DLNA Media Server
Compatible music services: TIDAL, Qobuz streaming Internet radio
Wireless Compatibility: AirPlay, BluetoothSongcast, RoonReady
Digital Inputs:
1 * AES / EBU
1 * Coaxial
1 * Toslink
1 * USB device to computer
2 * USB host forstorage and CAD
1 * RJ45 Gigabit Ethernet
1 * 802.11b / g / n / ac Tri-Band WiFi
Analog inputs:
One Line Input: (Input Sensitivity: 4Vrms)
One input MM Phono input (Gain: 36dB, max 65mV)
Analog Outputs:
  • Asymmetric RCA (6Vrms @ 0dBFS)
  • Gold plated stereo headphones
Supported Digital File Types:
  • AAFC, AIFF, ALAC, APE, DIFF, DSF, FLAC.
  • MP3, OGG, WAV, WV and WMA.
Resolution and sampling frequencies supported:
  • AllPCM formats from 44.1KS / s to 384KS / s to 32Bit ***
  • DSD64, DSD128, DSD256 ***
* Tested by AURALiC in "filter mode precise" on all sampling frequencies of the converter Streamer ALTAIR
** 32bit resolutions and 352.8KS / s and 384KS / s sampling frequencies are supported by the network input and USB 2.0 input
*** 32bit resolution is supported only through the network input and USB 2.0 input
***On standard 'DoP V1.1 or DSD native protocol and streaming network and USB input only
Control software and compatible interfaces:
  • AURALiC Lightning DS for iOS
  • Remote: AURALiC RC-1
  • OpenHome uPnP software compatible (Bubble uPnP, Banshee 2.4 and higher, Kinsky, Plex, Plug, VLC uPnP, Kodi.)
  • Roon Audio Compatible
Power consumption:
  • Reading: 450W max.
Dimension :
  • 33cm x 23cm x 6.5cm.
Weight:
  • 4.5kg.
Overview AURALiC POLARIS
[Img-20148-left-thickbox_default]
AURALiC Lighning DS Interface
[Img-20149-left-thickbox_default]
InputWiFi
InputXLR
InputPhono
InputRJ45
OutputSpeaker terminal
ColorSilver
The integrated DAC wireless WIFI POLARIS amplifier defines the AURALiC brand: Innovative technology, high resolution and musical sound, an...
