BLUESOUND POWERNODE EDGE Network Amplifier WiFi Bluetooth 5.0 2x40W 8Ω 24bit 192kHz Black
With the Powernode Edge, Bluesound unveils a network amplifier capable of developing a power of 2x40W under 8Ω. It will allow you to easily enjoy your music, including wireless, WiFi or Bluetooth. It thus becomes possible to broadcast your music remotely from your local network, a computer or a smartphone with ease. It's also the possibility to access your favorite streaming services and web radios but also to broadcast thanks to the protocols Spotify Connect, TIDAL Connect or AirPlay 2.
By buying this product you get 66 loyalty points
Reference : 16944
669,00 €tax incl.
557,50 € tax excl.
BlueSound Powernode Edge
Bluesound Powernode Edge Amplificateur Réseau WiFi Bluetooth 5.0 2x40W 8Ω 24bit 192kHz Noir
With the Powernode Edge, Bluesound unveils a network amplifier capable of developing a power of 2x40W under 8Ω. It will allow you to easily enjoy your music, including wireless, WiFi or Bluetooth. It thus becomes possible to broadcast your music remotely from your local network, a computer or a smartphone with ease. It's also the possibility to access your favorite streaming services and web radios but also to broadcast thanks to the protocols Spotify Connect, TIDAL Connect or AirPlay 2. Extremely versatile, the Powernode Edge even provides an HDMI eARC connector to connect the amplifier to a TV to broadcast sound in stereo or 4.1.
Wireless has never been easier
The Bluesound Powernode Edge connects easily to the local network and the Internet via its Gigabit RJ45 Ethernet port or wirelessly via the built-in dual-band WiFi connectivity. The amplifier is thus able to access music stored on devices on your network such as a computer or NAS. In addition, it supports the vast majority of current audio file formats and is capable of playing high-resolution streams up to PCM 24bit 192kHz as well as decoding MQA files notably broadcast via the Tidal platform.
Powerful, the Powernode Edge embeds a Quad-Core ARM Cortex-A53 1.8GHz processor, allowing it to guarantee a smooth use and reading.
In addition to accessing files stored on your network, the Bluesound amplifier will allow you to access major streaming and web radio services via its BluOS mobile application.
Bluetooth 5.0
To allow you to easily stream your music directly from a smartphone or tablet, the Powernode Edge is equipped with a Bluetooth 5.0 receiver. This one is compatible with the aptX HD transmission codec, ensuring a high quality sound reproduction in Bluetooth. It is also bidirectional and is therefore also capable of transmitting your audio content to a headphone or a Bluetooth speaker.
BluOS app & Multiroom
In order to offer an intuitive use, Bluesound proposes a dedicated control application, BluOS, available for free on iOS and Android devices. It allows you to take control of playback, manage your playlists and access streaming and web radio services. It also makes it possible to manage a multi-room environment, to broadcast your music throughout your home while controlling the whole thing from your application.
Compact & Powerful
Thanks to its DirectDigital™ amplifier delivering 2x40W power under 8Ω and ensuring a 91dB SNR and very low distortion, the Powernode Edge reproduces your music or movie audio tracks with precision, clarity and dynamics. It is also capable of decoding the Dolby Digital format, allowing it to be used in a wireless home theater installation.
Its compact form factor allows it to fit easily into any space. It can be placed on a desk or in a TV or HiFi cabinet. The Powernode Edge can even be wall-mounted using the included multi-orientation wall bracket.
Intuitive and vocal control
While the Bluesound Powernode Edge can be controlled from the BluOS mobile app, it can also be controlled from its elegant front panel touch interface. This provides backlit controls for controlling your music playback and accessing your favorites.
To take it a step further, the amplifier can even be controlled by voice, using smart assistants like Alexa, Google Assistant or Siri. In addition, it can be integrated into a home automation system through popular systems such as Lutron, Crestron, RTI or Elan.
Product typeNetwork amplifier
Inputs1x Ethernet RJ45 Gigabit 1000Mbps
1x Combined Mini-Toslink optical / Jack 3.5mm analog input
1x HDMI
1x USB-A
1x Jack 3.5mm IR input
Outputs1x RCA Subwoofer output
Speaker terminals
Wireless connectivityWiFi 802.11ac dual band
Two-way Bluetooth 5.0
OSBluOS
Control app compatibilité(BluOS)iOS, Android, Windows, Mac OS
CPUARM® Cortex™-A53, Quad-Core, 1.8GHz per core
Network file sharingSMB up to 200000 files
Supported streaming services (BluOS)Spotify
TIDAL
Deezer
Qobuz
Amazon Music
Napster
nugs.netBugs
IDAGIO
KKBOX
Neil Young Archives
CustomChannels
Qsic
Sound-Machine
Tunify
Supported webradios (BluOS)TuneIn
CALM Radio
SiriusXM
iHeartRadio
RADIO.com
Radio Paradise
LiveXLive
Supported control servicesControl 4
Crestron
ELAN
Lutron
Push
Roon
RTI
URC
Supported vocal assistantsGoogle Assistant
Amazon Alexa
Siri
WiFi transmission protocolsAirPlay 2
Spotify Connect
Tidal Connect
Roon Ready
Audio
Supported file formatsMP3, AAC, WMA, WMA-L, OGG, ALAC, OPUS, FLAC, MQA, WAV, AIFF, MPEG-4 SLS
Supported multi-channel audio formatsDolby® Digital
Supported sampling ratesPCM up to 24bit 192kHz
SNR-91dBA
THD+N0.008%
AmplificationDirectDigital™
Rated output power2*40W @ 8Ω
IHF Dynamic power80W @ 4Ω
50W @ 8Ω
Minimal impedance4Ω
Supply voltage100-240VAC
Max consumption210W
Dimensions219*193*44.5mm
Weight1.37kg
Package1x BlueSound Powernode Edge
1x 120VAC Power cable
1x 230VAC Power cable
1x Ethernet cable
1x Optical Toslink to Jack 3.5mm adapter
Metal mounting support
InputOptical Mini-Toslink
InputJack 3.5mm
InputRJ45
InputWiFi
InputHDMI
OutputSubwoofer
OutputSpeaker terminal
OutputBluetooth
Channel2 (Stereo)
Amplifier chipN/A
Power (W)40.0
With the Powernode Edge, Bluesound unveils a network amplifier capable of developing a power of 2x40W under 8Ω. It will allow you to...
