FOSI AUDIO E10 Amplifier TPA3251D2 MS8413 Bluetooth 5.0 24bit 192kHz 2x125W 4 Ohm
The Fosi Audio E10 is a Class D amplifier that is both powerful, efficient and affordable. It embeds a TPA3251D2 amplifier chip allowing it to develop a comfortable power of 2*125W under 4Ω with a high efficiency, a low distortion and a wide dynamic range, for a sound restitution as precise as musical.
Reference : 17006
185,00 €tax incl.
154,17 € tax excl.
Fosi Audio E10
Amplifier TPA3251D2 MS8413 Bluetooth 5.0 24bit 192kHz 2x125W 4Ω
Fosi Audio E10 Amplificateur TPA3251D2 MC8413 Bluetooth 5.0 24bit 192kHz 2x125W 4Ω
The Fosi Audio E10 is a Class D amplifier that is both powerful, efficient and affordable. It embeds a TPA3251D2 amplifier chip allowing it to develop a comfortable power of 2*125W under 4Ω with a high efficiency, a low distortion and a wide dynamic range, for a sound restitution as precise as musical. Moreover, the E10 offers a complete range of connectors allowing it to adapt to most of the use scenarios. We find stereo RCA, Toslink optical, coaxial and a USB-A port for storage device, completed by a Bluetooth 5.0 reception capacity. Practical, the latter offers the possibility of broadcasting and controlling its music remotely easily from a smartphone or a tablet for example. On the output side, the amplifier offers of course speaker terminals but also a pre-out RCA output that can be used as a subwoofer output.
1USB-A Input (USB Host)
2Play Button
3Next track button
4Previous track button
5ON/OFF button
6Screen
7Input selection button
8Volume +
9Volume -
10Bluetooth antenna connector
11Coaxial input
12Optical input
13RCA 1 input
14RCA 2 input
15RCA / Subwoofer output
16Right channel speaker output
17Left channel speaker output
18Power supply input
Product typeAmplifier
InputsBluetooth 5.0
2* Stereo RCA
1* USB-A (USB Host)
1* Optical Toslink
1* Coaxial
OutputsSpeaker terminals
1* Steroe RCA / Subwoofer output
Amplification chipTPA3251D2
DAC chipMS8413
Bluetooth chipATS2825
Output power2* 125W @ 4Ω, 1% THD
Frequency response10Hz - 60kHz (±6dB)
SNR92dB
Dynamic range105dB
THD≤ 0.01%
Supported sampling rates (optical/coaxial)PCM up to 24bit 192kHz
Supply voltage220-250VAC (power cable included)
Dimensions (W*D*H)351*320*65mm
Weight3.6kg
ColorFront panel : Silver
Rest of the body : Black
Package1* Fosi Audio E10
1* Power cable
1* Antenna
1* Remote controle
1* RCA cable
OutputSubwoofer
OutputSpeaker terminal
ColorSilver
Channel2 (Stereo)
Channel2.1
Amplifier chipTPA3251D2
Power (W)125.0
Remote ControlYes
Quoi demander de plus....!
ce petit ampli a été pour moi une révélation......branché sur des Klipsch RB81 MKII et alimenté par un Yamaha WXC-50 sur Netradio. La restitution est très dynamique, détourée avec des attaques franches et beaucoup de grain dans la tessiture de timbres. En fait, c'était un cadeau pour un ami mais je vais en commander un pour moi.....et très rapidement. Cet ampli est de plus très fonctionnel et doté d'une connectique presque complète, 2 prises numériques, 2 RCA, une sortie PréOUt pour caisson, 1 USB qui lit les Flac (il manque peut-être une HDMI Arc). Son esthétique sobre et original fait classieux et pas bling bling ! Vraiment excellent rapport qualité prix. Top
This review has been posted for FOSI AUDIO E10 Amplifier TPA3251D2 MS8413 Bluetooth 5.0 24bit 192kHz 2x125W 4 Ohm
The Fosi Audio E10 is a Class D amplifier that is both powerful, efficient and affordable. It embeds a TPA3251D2 amplifier chip allowing it to...
