SHANLING CA80 Amplifier Class D ICEPower 100AS2 CD Player DAC ES9219MQ Bluetooth 5.0 100W 4 Ohm Silver
The Shanling CA80 is a particularly versatile integrated amplifier, CD player and DAC. It performs these tasks brilliantly, thanks to its meticulous architecture and high-quality components, enabling it to deliver clear, precise sound reproduction. Despite its compact size, it offers incredible versatility, making the CA80 a true centerpiece of any HiFi audio system.
By buying this product you get 44 loyalty points
Reference : 18272
449,00 €tax incl.
374,17 € tax excl.
Shipping date: 13-05-2025.
Shanling CA80
SHANLING CA80 Amplifier Class D CD Player DAC ES9219MQ Bluetooth 5.0 100W 4 Ohm Silver
Class D amplifier
The CA80's efficient and powerful Class D amplification stage is based on an ICEPower 100AS2 module. In addition to high efficiency, this module delivers power ratings of 2x100W at 4 Ohm or 2x50W at 8 Ohm. What's more, it ensures impeccable sound quality, with precise, dynamic reproduction.
ES9219MQ DAC
The CA80's digital-to-analog conversion section uses an ESS Sabre ES9219MQ DAC for first-rate decoding. This configuration offers both clarity and power for an optimal musical experience. This chip also supports high sampling rates, up to PCM 32bit 384kHz and DSD256. What's more, it is capable of decoding MQA streams, guaranteeing sound quality as close as possible to studio recording.
Philips CD player & USB input
The front panel of the CA80 features a Philips CD player, using Sanyo HD860 laser technology to ensure optimum playback of your audio CDs. Playback quality is enhanced by the integration of an Ingenic X1000 microprocessor, providing the player with significant data processing power.
The CA80 also features a USB input. This allows playback of high-resolution audio files up to PCM 32bit 384kHz and DSD256.
Bluetooth 5.0
With its Bluetooth 5.0 module, the Shanling CA80 is able to receive audio streams wirelessly, from a smartphone or tablet for example, for practical and intuitive use. It also supports the high-resolution LDAC audio codec, ensuring high-quality wireless transmission and playback.
Comprehensive connectivity
The versatile Shanling CA80 features an additional RCA input, transforming it into a true integrated amplifier. This means you can connect a wide range of sources. In addition, the device offers several output modes, from Optical Toslink to RCA pre-out. The front panel of the CA80 even features an amplified 3.5mm jack output for headphone listening.
Eddict Player app
The amplifier can be controlled remotely via its remote control or the free Eddict Player mobile app, available for both Android and iOS. In addition to managing playback, the latter offers access to the device's various functions.
1CD player
2Volume display
3IR receiver
4Screen
5USB input
6Previous track
7Play / Pause
8Next track
9Stop / Eject
10Volume
11Power / Input selection button
12Status indicator
13Jack 3.5mm headphone output
1Power button
2Power input
3Speaker output
4AUX RCA input
5RCA pre-out
6Optical Toslink output
7Bluetooth antenna
Product typeCD Player
Amplifier
DAC
DAC chipES9219MQ
MicroprocessorX1000
Control appEddict Player
Amplifier power output100W @ 4 Ohm, 0.3% THD
50W @ 8 Ohm 0.3% THD
Frequency response (amp)20Hz-20kHz (-0.2dB)
THD+N (amp)0.003%
Channel separation (amp)80dB @ 32 Ohm
SNR (amp)108dB
Headphone output power130mW @ 32 Ohm
Frequency response (headphone output)20Hz-40kHz (-0.2dB)
THD+N (headphone output)0.0015%
Channel separation (headphone output)75dB @ 32 Ohm
Dynamic range (headphone output)119dB
SNR (headphone output)118dB
Output impedance (headphone output)< 1 Ohm
Output level (line out)2Vrms
Frequency response (line out)20Hz-40kHz (-0.2dB)
THD+N (line out)0.002%
Channel separation (line out)85dB
SNR (line out)116dB
InputsCD
Bluetooth
1* USB-A
Outputs1* Optical Toslink
1* Jack 3.5mm
1* RCA
Supported Bluetooth codecsSBC, AAC, LDAC
DSD up to DSD256
MQA
Supply voltage100-240VAC
Consumption20W
Dimensions250*205*52mm
Weight2.8kg
ColorSilver
Package1x Shanling CA80
1x Power cable
1x Remote control
InputCD
OutputJack 3.5mm
OutputOptical Toslink
OutputSpeaker terminal
ColorSilver
Channel2 (Stereo)
Amplifier chipICEpower 100AS2
Power (W)100.0
The Shanling CA80 is a particularly versatile integrated amplifier, CD player and DAC. It performs these tasks brilliantly, thanks to its...
