SMSL DA-6 Class D Amplifier Infineon 2x70W 4 Ohm Silver
The SMSL DA-6 is a small, practical, high-performance and affordable Class D amplifier based on an Infineon amplifier chip offering high efficiency and capable of developing 2x70W of power under 4Ω, while offering dynamic and accurate sound reproduction. Its simple and efficient design endows it with a stereo RCA input, LED display and digital volume control, all dressed in a robust and modern CNC machined aluminum chassis.
Reference : 16800
105,00 €tax incl.
87,50 € tax excl.
Shipping date: 13-05-2025.
SMSL DA-6
Class D Amplifier Infineon 2x70W 4Ω Silver
SMSL DA-6 Amplificateur Class D Infineon 2x70W 4Ω
The amplifier adds to this the possibility of adjusting the bass and treble levels over a range of ±14dB (Tone mode) as well as five predefined equalizers and a mode allowing to bypass all equalizers (Direct mode). This makes it possible to adapt the sound of the DA-6 to your listening style, your favorite music genre and your audio system.
1Display
2IR Receiver
3Multifunction button
4RCA input
5Right channel speaker output
6Left channel speaker output
7Power connector
Product typeAmplifier
Amplification typeClass D
Input1x Stereo RCA
OutputSpeaker terminals
Output power2x 70W @ 4Ω
Frequency response20Hz - 40kHz
Bass/Treble adjustable gain-14dB / +14dB
THD+N0.004%
Channels separation91dB (1kHz)
Input sensitivity400mVrms
SNR103dB
Max input voltageLow gain: 2Vrms
High gain: 1.2Vrms
Supply voltage24VDC (Power supply included)
Consumption36W
Dimensions140 x 110 x 28mm
Weight350g
ColorSilver
SMSL DA-6 Amplificateur Class D Infineon 2x70W 4Ω SMSL DA-6 Amplificateur Class D Infineon 2x70W 4Ω
ColorSilver
Channel2 (Stereo)
Amplifier chipN/A
Power (W)70.0
Remote ControlYes
Un amour !
Couplé au DAC SMSL SU-6, le résultat est formidable. Transparence et silence de fonctionnement, rien à dire au niveau des sens : c’est le fond noir.
Utilisé dans une pièce de 16m², bruit de fond +46dB, le SMSL SA-6 se montre totalement suffisant; avec enceintes 84 dB/8 Ohms. Le potentiomètre reste généralement au 2⁄3 soit 20/60 à l’écran, le niveau sonore atteint aisément les 90 dB à 2m. Cela permet de s’approcher du point de puissance qui optimise ses performances. Les réglages de tonalité (Bass/Treble) sont excellents et sans distorsion. La télécommande est parfaite.
Son alimentation externe est pour moi un point positif avec une longueur du câble respectable, il ne chauffe pas et remplace efficacement un amplificateur AB vintage 12 fois son volume. Le SMSL DA-6 est une solution élégante et discrète, il a les épaules pour tout usage raisonnable. C’est un appareil parfait pour transitionner vers un système plus ambitieux et, peut-être que comme moi, vous aurez même du mal à justifier de passer à autre chose par la suite.
This review has been posted for SMSL DA-6 Class D Amplifier Infineon 2x70W 4 Ohm Silver
The SMSL DA-6 is a small, practical, high-performance and affordable Class D amplifier based on an Infineon amplifier chip offering high efficiency...
