TINYSINE TSA3611 Class D Amplifier TPA3116 2x35W 4 Ohm
This small TinySine TSA3611 Class D amplifier is based on a TPA3116 chip allowing it to develop 2x35W and to be associated with passive speakers in 4 or 8Ω The amplifier has a volume control knob and an ON/OFF switch on the front panel.
Reference : 13844
44,90 €tax incl.
37,42 € tax excl.
Tinysine TSA3611
Class D Amplifier TPA3116 2x35W 4Ω
Tinysine TSA3611 Amplificateur Class D TPA3116 2x35W 4Ω
This small TinySine TSA3611 Class D amplifier is based on a TPA3116 chip allowing it to develop 2x35W and to be associated with passive speakers in 4 or 8Ω The amplifier has a volume control knob and an ON/OFF switch on the front panel. On the connector side, there are simply speaker terminals and an RCA stereo input at the output.
Product typeAmplifier
Amplification typeClass D
Amplification chipTPA3116
Power2x35W @ 4 Ohm
Input1x Stereo RCA
OutputSpeaker terminal
Power supply12-24V DC via Jack DC
ProtectionsOver current, thermal protection
Dimensions75 x 160 x 48mm
Weight420g
Power 24V DCPower adapter sold separately
Measurements
ParameterConditionMin.Typ.Max.
Supply voltage-12V DC21V DC24V DC
Maximum current100W @ 4Ω-5.29A
Efficiency50W @ 4Ω87%-92%
Minimum load impedance-3.2Ω--
Switching frequencySD Floating-394kHz
Gain-24dB25dB26dB
Input sensitivity (RMS)@ 4Ω, 50W, 1kHz-808mW-
Input impedance--22kΩ-
Output power@ 4Ω THD+N 1%-36W-
@ 4Ω THD+N 10%-50W-
Frequency response @ +/-3dB@ 4Ω20Hz-20kHz
THD@ 4Ω, 1W, 1kHz-0.0299%-
@ 4Ω, 10W, 1kHz-0.073%-
Channel2 (Stereo)
Amplifier chipTPA3116
Power (W)35.0
This small TinySine TSA3611 Class D amplifier is based on a TPA3116 chip allowing it to develop 2x35W and to be associated with passive speakers in...
