TOPPING MX3 Class-D Amplifier TDA7498 BT USB SPDIF 2x40W / 4 Ohm Black
TOPPING MX3 Full Digital Amplifier FDA XMOS Class D 2x 38W / 8 Ohm Black
This small 2X40W Bluetooth Topping MX3 amplifier is a real quality solution. With a successful design in an aluminium case with a readable display, it will find a place of choice on a desk, a piece of furniture, a shelf.
4.8 / 5
Reference : 12277
129,00 €tax incl.
107,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
The Topping MX3 is now replaced by the Topping MX5.
Topping MX3
All in one, one for all
topping MX3
This small 2X38W Bluetooth Topping MX3 amplifier is a real quality solution. With a successful design in an aluminium case with a readable display, it will find a place of choice on a desk, a piece of furniture, a shelf.
Rich and mature connection technology
topping MX3
The Topping MX3 is a true Swiss army knife in a compact format that allows you to broadcast the sound of your TV through its optical/coaxial or analog input on speakers or headphones. It lets you listen to your favorite music stored on a computer with its USB input. Thanks to its subwoofer, it is an excellent starting point for 2 satellite speakers and active subwoofer.
Bluetooth NFC and remote control
topping MX3
With a Bluetooth A2DPV1.2 input, AVRCPV1.4 the MX3 allows you to play music from your smartphone, Android tablet or iOS. Pairing is done by NFC, just approach your smartphone on the MX3 and the trick is done: No buttons, no codes to type.
Hifi level components
topping MX3
The MX3 benefits from all the attention with first-class components that guarantee high quality audio reproduction in a liliputian format. It will also be an excellent amplifier for headphones from 16 to 300 Ohm.
Topping MX3 review by Qobuz
" This digital amplifier with DAC is a very pleasant and uncomplicated device to use and offers a very responsive sound reproduction whose natural roundness can be compensated for by the bass and treble correctors. "
Test Qobuz
TECHNICAL SPECIFICATIONS
topping MX3
  • Technical specifications :
  • Bluetooth 4.0 NFC Bluetooth stereo amplifier
  • Multifunction display with dimmer function
  • 3 digital inputs, one Bluetooth wireless input, one analog input
  • CNC aluminium chassis
  • Bandwidth: 20Hz to 200Khz +/-1dB
  • Signal-to-noise ratio: 115db on headphones, 91dB on loudspeaker outputs
  • Gain: + 29.6dB
  • Total harmonic distortion: 0.05%.
  • Diaphony -75dB
  • Output power:
  • Output power on gold-plated terminals: 2X38W on 8ohm
  • Output power on gold-plated terminals: 2X40W on 4ohm
  • Headphone output power on 3.5mm jack: 2X257mW on 32ohm THD 1%.
  • Headphone output power on 3.5mm jack: 2X42mW on 300ohm THD 1% THD
  • RCA line inputs:
  • Analog RCA stereo line analog inputs
  • 24-bit 96Khz USB Digital Input 24-bit 96Khz
  • Toslink Digital Input 24bit 192Khz
  • Coaxial 24bit digital input Coaxial 24bit 192khz
  • Line and headphone outputs:
  • 3.5mm stereo headphone jack output from 16 to 300 Ohm
  • Subwoofer RCA X1 Subwoofer output line level 2V (fixed cutoff frequency)
  • Auxiliary analog stereo auxiliary stereo fixed line output
  • Coaxial digital output SPDIF
  • Power supply:
  • A 230V to 24V 3.75A adapter supplied
  • Dimension and weight:
  • 185x122x38mm
  • 475g
  • One supplied remote control, one USB cable, one antenna
OutputSubwoofer
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTDA7498E
Power (W)38.0
10 reviews
Ampli complet et de qualité
Je voulais un ampli avec une connectique complète pour le brancher à une de mes squeezebox Touch. Mes critères était l'esthétique, la qualité du matériel et la discrétion.
La boite dans lequel le MX3 arrive est de qualité, l'ampli est bien protégé. L'ampli, la télécommande, l'antenne BT et le transformateur sont bien emballés individuellement; il manque seulement les piles pour la télécommande.
Avant de le démarrer, j'ai attendu qu'il soit à la température de la pièce. Le branchement se fait très facilement. Toutes les prises derrière l'ampli sont protégées par des bouchons discrets. Avec mes gros doigts, ce fut un peu long car les connectiques sont très proches les unes des autres.
J'ai branché ma squeezebox Touch en RCA-RCA et de vieilles enceintes JBL SCS 178 4 Ohm.
A la première écoute j'ai senti que la puissance de l'ampli est inférieur au Topping PA3, logique c'était dans les spécifications !!! J'imagine qu'il faut laissé l'ampli fonctionner de nombreuses heures pour qu'il "chauffe". Mon premier test dura 2h : ce fut suffisant pour être satisfait de mon achat. Je ne pense pas avoir les enceintes adéquates mais pour l'instant je me contente de cela. Mon prochain test sera en SPDIF et avec des flac.
Concernant l'affichage celui-ci peut être réglé en intensité lumineuse uniquement via la télécommande. Cette dernière sert à régler aussi les bass et treble.
Concernant Audiophonics : j'ai reçu le colis en 2 jours : merci ! Le colis était écrasé du coté du rembourrage. Je l'ai ouvert à la poste et constatant aucun coup sur le matériel j'ai gardé le colis.
This review has been posted for TOPPING MX3 Class-D Amplifier TDA7498 BT USB SPDIF 2x40W / 4 Ohm Black
Beau son
Simple a mettre en oeuvre et a manipulé.
Sur deux vielles dm 12 il marche mieux que mon Cambridge.
Happy
Excellent petit ampli...!!!
Associé à une paire d'enceinte Cabasse "bibliothèque", il se fait très discret dans mon salon, dans le meuble télé.
Associé à mon téléphone en Bluetooth, j'écoute musisque et radio. Relié à la télé, en connexion optique, il me sert d'Home cinéma.
Le son est claire et très largement assez puissant pour une pièce de 35 m².
Bref, pleinement satisfait de cet achat !
ampli
Very average sound. The remote has a poor range. After one year of use, the knob does not work, but is not used much. As a discrete amplifier for TVs and satellite tuners is fine. Still working every day with KEF
Un bel ampli digne de la classe D dont on dit du bien
Cet ampli est très compact et propose pourtant une connectivité complète avec USB, Opt, Coax, Line In et Bluetooth. Le bruit blanc est très maîtrisé, il faut monter le volume plus que de raison pour le rendre audible. Les qualités audio sont réelles, il passe le test du solo piano sans scintillements, et je l'ai testé avec succès avec des titres pourtant difficiles à rendre en hi-fi. Mon NAD coûte 4x plus cher et il n'est pas 4x meilleur. A acheter les yeux fermés, merci Audiophonics pour sa sélection.
This small 2X40W Bluetooth Topping MX3 amplifier is a real quality solution. With a successful design in an aluminium case with a readable display,...
