Petit ampli qui bouge très bien une paire de cabasse, bonne connexion et bonne puissance, le son est pas mal du tout...
Amplifier 2.1 Class D Bluetooth 5.0 Receiver aptX HD QCC3034 2x50W
The 1Mii B08s is a Bluetooth receiver with integrated amplifier that is both affordable and powerful. Incorporating a Qualcomm QCC3034 chip, it features Bluetooth 5.0 reception with support for the high-resolution transmission codecs aptX, aptX LL and aptX HD. Equipped with two antennas, it allows long-distance transmission, up to 50m without obstacles. A 3.5mm jack input is also available.
Its amplification stage allows it to develop a power of 2x50W, ideal to accompany small passive bookshelf loudspeakers.
On the output side, there are of course speaker terminals, but also a Subwoofer output on RCA.
The front panel of the device has three buttons, allowing you to adjust the volume level, but also to adjust the bass and treble levels.
Product type | Bluetooth amplifier |
Inputs | Bluetooth 5.0 1x Jack 3.5mm 1x Stereo RCA 1x Optical Toslink |
Outputs | 1x Speaker terminals 1x Subwoofer RCA |
Bluetooth version | 5.0 |
Supported Bluetooth profiles | A2DP AVRCP |
Supported Bluetooth codecs | SBC aptX aptX LL aptX HD |
Max transmission distance | Without obstacles : 30m |
Power output | 2x 50W / 4 Ohm |
Operating temperature range | -10°C / +45°C |
Supply voltage | 24VDC 4A |
Dimensions | 136 x 101 x 45mm |
Weight | 230g |
color | Black |
Package | 1x 1Mii B08s 1x Power supply 24V 4A |
Input | RCA |
Input | Optical |
Input | Jack 3.5mm |
Input | Bluetooth |
Output | Speaker terminal |
Output | Subwoofer |
DAC / ADC Chip | NC |
Max sampling rate | NC |
Color | Black |
Channel | 2.1 |
Class | Class D / T |
Amplifier chip | N/A |
Power (W) | 50.0 |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
