The Aiyima A09 is a 5.1-channel amplifier based on the use of various chips to process the signal. These include an AC6926A processor, MS8412 optical/SPDIF interface, NE5532 OPAs and several TPA3116D2 amplifier chips. This chipset offers an output power of 5x50W +50W into 4 ohm to the Aiyima A09, i.e. a substantial power reserve for sound reinforcement in any space. On the interface side, it features analog RCA, optical toslink, SPDIF coaxial, USB-A (disk) and Bluetooth inputs, while on the output side, there are 6 speaker terminals, including one for passive subwoofer, as well as an output for active subwoofer. The front panel features volume control for each output channel, as well as bass and treble tone control. A number of buttons offer the following functions: previous, pause/play, next, and input selection. In short, this little amplifier is perfect for 2.1/5.1 multichannel amplification, or simply stereo, depending on your needs.
Please note that digital inputs do not support 5.1 configuration. Only analog inputs can output a 5.1 configuration. You'll need to pair the Aiyima A09 with several sources, a multichannel sound card or an AV processor to benefit quickly and easily from its 5.1 functionality.
The Aiyima A09's 50W of power per channel offers a nice reserve of power. It also manages to maintain a low distortion level for clear, detailed overall sound reproduction.
The Aiyima A09 also supports Bluetooth functionality for fast use with a smartphone, for example. Bluetooth supports up to 16bit 44.1-48kHz.
The Aiyima A09 has two separate power supply ports. It can automatically detect whether it is being powered by one or two ports simultaneously. Both power supplies must deliver the same voltage and current. The A09 is supplied with a 24V DC 8A power supply.
1 | On/Off/Source selection button |
2 | LED source indicators |
3 | Previous/pause/play/next button |
4 | Subwoofer volume |
5 | Central volume |
6 | Surround volume |
7 | Front volume |
8 | Overall volume |
9 | Bass control |
10 | Treble control |
11 | USB-A input (Disk) |
12 | Antenne Bluetooth |
13 | Toslink optical input |
14 | SPDIF coaxial input |
15 | RCA 2.0 input |
16 | RCA 5.1 input |
17 | Passive subwoofer output |
18 | Auxiliary power port |
19 | Main power port |
20 | 5.1-channel speaker terminal output |
Product type | Multichannel amplifier |
Chipset | AC6926A + MS8412 + NE5532 + TPS5430 + TPA3116D2 |
Inputs | Bluetooth 1x Stereo RCA input 1x Optical Toslink 1x SPDIF Coaxial 1x RCA 5.1 input |
Sortie | 6x Speaker terminals (2.0/2.1/5.1) |
SNR | ≥ 100dB |
THD | 0.05% |
Bass and treble adjustment | ±6dB |
Frequency response | 20Hz-20kHz (±1.5dB) and subwoofer 20Hz-120Hz |
Output power | 5x50W + 50W @ 4 ohm |
Supported sample rates | Bluetooth : 16bit 44.1-48kHz Optical Toslink/SPDIF Coaxial: up to 24bit 192kHz |
Power supply | 15V-24V DC (24V DC 8A power supply included) |
Dimensions | 130 x 231 x 49mm |
Weight | 1.2kg |
Color | Black |
Package | 1x Aiyima A09 1x 24V 8A power supply |
Input | RCA |
Input | Optical |
Input | USB |
Input | SPDIF |
Input | Bluetooth |
Output | Speaker terminal |
Output | Subwoofer |
Color | Black |
Channel | 2 (Stereo) |
Channel | 5.1 |
Channel | 2.1 |
Class | Class D / T |
Amplifier chip | TPA3116D2 |
Power (W) | 50.0 |
Remote Control | No |
