AIYIMA B07 Amplifier
Aiyima's B07 is a integrated amplifier with 3 channels, including one dedicated to the subwoofer and an auxiliary output. It is capable of delivering considerable output power thanks to its 6 NE5532 OPAs and TPA3255 amplifier chip. To ensure flexibility of use, the Aiyima B07 has a Bluetooth 5.2 chip compatible with aptX, aptX low latency and aptX HD.
Reference : 19712
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 06-05-2025.
AIYIMA B07 Amplifier 2.1 Bluetooth 5.2 Class D TPA3255 2x250W+300W 4Ω
AIYIMA B07 : Front view
Aiyima's B07 is a integrated amplifier with 3 channels, including one dedicated to the subwoofer and an auxiliary output. It is capable of delivering considerable output power thanks to its six NE5532 OPAs and TPA3255 amplifier chip. To ensure flexibility of use, the Aiyima B07 has a Bluetooth 5.2 chip compatible with aptX, aptX low latency and aptX HD.
Aiyima B07 : An impressive amplification
Aiyima's B07 is based on a TPA3255 amplifier chip and six NE5532 OPAs. This gives it an output power of 250W per channel for the speakers and 300W for the subwoofer.
AIYIMA B07 : TPA3255 amplification chip
AIYIMA B07 : heat dissipation diagram
Aiyima B07 : Excellent heat dissipation
When designing the B07, particular attention was paid to dissipating the heat generated by the amplification process. As a result, the chassis has numerous openings, allowing efficient air circulation for rapid heat dissipation.
Aiyima B07 : 2.1 configuration
The outputs of the Aiyima B07 allow it to be used in a 2.1 configuration with speakers and a passive subwoofer, but the auxiliary output also allows you to extend this configuration by connecting an active speaker or subwoofer, or even another power amplifier.
AIYIMA B07 : Input/output diagram
Product typeIntegrated amplifier
Amplification typeClass D
Amplification chips6x NE5532 OPAs
1x TPA3255
Bluetooth chipQCC3040
Codecs supportedAAC
SBC
aptX
aptX low latency
aptX HD
Number of channels2.1
InputsBluetooth
RCA
AUX
Outputs3x Speaker terminals (including one for subwoofer)
1x AUX
Output powerSpeakers : 2x250W @ 48V 10A, 4Ω
Subwoofer : 300W @ 48V 10A, 4Ω
Output impedance4-8Ω
Total harmonic distortion (THD)0.01%
Signal-to-noise ratio (SNR)≥ 108db
Frequency responseSpeakers : 20-20kHz (±1dB)
Subwoofer : 50-220Hz
Speaker treble and bass adjustment range±6dB
Subwoofer adjustment range±4db
Input sensitivity2V
AUX output level1.4V
Power supply voltage24-48V DC (primary and secondary supplies need the same voltage)
Dimensions154 x 124 x 42mm
Weight800g
Package1x Aiyima B07
1x Bluetooth antenna
1x Power adapter DC 48V5A
InputAUX
OutputSpeaker terminal
Channel3
Amplifier chipNE5532
Amplifier chipTPA3255
Power (W)300.0
Power (W)250.0
AIYIMA B07 Amplifier 2.1 Bluetooth 5.2 Class D TPA3255 2x250W + 300W 4Ω
Aiyima's B07 is a integrated amplifier with 3 channels, including one dedicated to the subwoofer and an auxiliary output. It is capable of...
