AIYIMA D03 Full Digital Amplifier FDA 2.1 TAS5624 Bluetooth 5.0 aptX HD 2x120W 4 Ohm
Aiyima's D03 is an FDA (Full Digital Amplifier) amplifier offering a nice energy reserve as well as a precise and transparent sound reproduction. It is indeed capable of developing no less than 2x120W under 4Ω (THD+N 1%) with a high efficiency, thanks to a TI TAS5624A amplifier chip.
Reference : 15692
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 04-06-2025.
    Aiyima D03
    Full Digital Amplifier FDA 2.1 TAS5624A Bluetooth 2x120w 4 Ohm
    Aiyima D03 Amplificateur FDA 2.1 TAS5624A Bluetooth 2x120W 4Ω
    Aiyima's D03 is an FDA (Full Digital Amplifier) amplifier offering a nice energy reserve as well as a precise and transparent sound reproduction. It is indeed capable of developing no less than 2x120W under 4Ω (THD+N 1%) with a high efficiency, thanks to a TI TAS5624A amplifier chip. It also benefits from a particularly complete connectivity, with USB-B, Optical Toslink, Coaxial, stereo RCA (ADC PCM1808) as inputs, but also a Bluetooth 5.0 reception. Practical, this last one allows to diffuse remotely its music, from a smartphone, while taking advantage of the high resolution Bluetooth codecs aptX and aptX-HD. On the output side, there are of course speaker terminals but also an output for active subwoofer, on RCA connector.
    Product typeAmplifier
    Amplifier typeFDA
    Output power2x120W @ 4Ω, 32V, 1% THD+N
    2x60W @ 8Ω, 32V, 1% THD+N
    2x140W @ 4Ω, 32V, 10% THD+N
    2x75W @ 8Ω, 32V, 10% THD+N
    InputsBluetooth 5.0
    1x USB-B
    1x Optical Toslink
    1x Coaxial
    1x Stereo RCA
    OutputsSpeaker terminals
    1x RCA output for active subwoofer
    Amplification chipTAS5624A
    ADC chipPCM1808
    SPDIF InterfacesCS8422
    TAS5548
    Bluetooth chipQCC3034
    Supported Bluetooth codecsAAC, SBC, aptX, aptX-LL, aptX-HD
    Supported sampling ratesPCM up to 24bit 192kHz
    USB CompatibilitéWindows XP / 7 / 8 10
    Mac OS
    Linux
    OTG smartphones
    SNR93dB
    Bass / Treble settings±14dB
    Input sensitivity0.775V
    Frequency response20Hz-20kHz (±1.25dB)
    Subwoofer output level2.1V
    THD0.001% (1kHz, 1W)
    Speaker impedance4-8Ω
    Supply voltage24 - 36VDC on DC 5.5/2.5mm jack (32V 5A power supply included)
    Dimensions151 x 141 x 37mm
    Weight670g
    Housing materialAluminum
    Package1x Aiyima D03
    1x Power supply
    1x Bluetooth antenna
    1x Remote control
    1x USB Cable
    1x Optical cable
    OutputSubwoofer
    OutputSpeaker terminal
    Channel2.1
    ClassFDA
    Amplifier chipTAS5624
    Power (W)120.0
    Remote ControlYes
    11 reviews
    exellent petit FDA
    comme toujours commandé un matin avant 10h reçus le lendemain !! utilisation pour l'audio de mon PC en combinaison avec un dac SMSL SU-1 pour alimenter des petites enceintes avec un rendement proche des 85 db le DO3 se comporte très bien niveau alimentation et musicalement très neutre, comparé à mon Fosi audio V3 qui est plus puissant et plus pêchu je trouve le DO3 plus adapté à mon utilisation d'écoute de proximité
    ses 2 modèles sont vraiment étonnants !
    This review has been posted for AIYIMA D03 Full Digital Amplifier FDA 2.1 TAS5624 Bluetooth 5.0 aptX HD 2x120W 4 Ohm
    Le AIYIMA D03 est un très bon amplificateur classe D. Etant mon 4ème, celui-ci est le plus naturel et dynamique. Excellent, même à volume très élevé... Je l'utilise dans 25m2 sur un woofer SBAcoustics + tweeter à ruban + sub. La sortie sub passive est bonne, la sortie USB est largement supérieure à la sortie RCA. Je n'ai pas testé la Coaxiale ni l'Optique.
    Comme il est dit dans un autre commentaire et sur certains forums anglo-saxons les basses sont fermes et profondes.
    Une précision quand même, en le branchant la 1ère fois je me suis aperçu que les basses étaient poussées à +14db. Le S.A.V d'Audiophonics m'a fait savoir qu'il peut y avoir des modèles dont les réglages ne sont pas remis à zéro suite au contrôle qualité, donc à vérifier si vous évaluez votre D3 au premier branchement.
    Très bonne qualité sonore pour le prix
    Ce petit ampli a une qualité sonore très bonne pour sa taille et son prix. Je l'utilise avec des enceintes bibliothèque Focal. Je le recommande !
    Petit ampli qui tient ses promesses
    Malgré mes craintes au sujet des FDA et de leur absence de boucle de rétroaction avec pour conséquence un faible facteur d'amortissement, cet ampli dépasse mes espérance en terme de qualité sonore (malgré des enceintes bibliothèque relativement basiques)
    L'utilisation via Bluetooth. aptx-hd est vraiment très bonne même si les entrées numériques sont permettent une diffusion encore plus qualitatives.
    Il est installé dans une résidence secondaire et c'est juste parfait.
    Je l'ai également testé sur des enceintes colonnes et avec un streamer node, le son est excellent.
    Très bien !
    Ampli compact par sa taille mais belle restitution sonore sur mes triangle antal 902. Son précis et transparent sur tous types de music ( jazz, chant, pop). Ecoute en flac uniquement pour le moment. Belle puissance en réserve et surprise! Graves profonds!!
    et fermes . Borniers enceintes un peu petits.
    Aiyima's D03 is an FDA (Full Digital Amplifier) amplifier offering a nice energy reserve as well as a precise and transparent sound...
