BERRYBAK HEV250 Bluetooth 5.0 Amplifier TAS5768 2x 36W @ 4 ohm aptX HD and Splitter Audio Extractor HDMI 2.0 4K 60Hz
The BerryBak HEV250 is a versatile device designed to enhance your home theater listening experience. It integrates a TAS5768 I2S AMP IC amplifier as well as a speaker output on a Phoenix male connector and Bluetooth 5.0 functionality thanks to a Qualcomm QCC3034 chip. This little device is capable of delivering 2x 36W @ 4 ohm (THD+N=1%) and supports high-resolution Bluetooth codecs.
Reference : 18980
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 13-05-2025.
BERRYBAK HEV250 picture
The BerryBak HEV250 is a versatile device designed to enhance your home theater listening experience. It integrates a TAS5768 I2S AMP IC amplifier as well as a speaker output on a Phoenix male connector and Bluetooth 5.0 functionality thanks to a Qualcomm QCC3034 chip. This little device is capable of delivering 2x 36W under 4 ohm (THD+N=1%) and supports high-resolution Bluetooth codecs: SBC, AAC, aptX, aptX LL and aptX HD. It also acts as an HDMI extractor and splitter, with one HDMI input port and two HDMI output ports. A 3.5mm jack output allows you to listen through headphones.
BERRYBAK HEV250: Bluetooth 5.0 reception
The BerryBak HEV250 is equipped with a Qualcomm QCC3034 receiver chip, enabling it to support high-fidelity Bluetooth codecs: SBC, AAC, aptX, aptX LL and aptX HD.
Puce Bluetooth QCC3034 du BERRYBAK HEV250
Photo de la puce d'amplification TAS5768
BERRYBAK HEV250 : I2S TAS5768 Amplifier
A TAS5768 I2S AMP IC amplifier chip enables the BerryBak HEV250 to deliver 2x 36W @ 4 Ohm (THD+N=1%). Whether you use the HDMI input or Bluetooth, you'll be able to obtain consistent power with an SNR of up to 104.71dB and a THD+N of just 0.013% for a highly qualitative audio experience. An output on a Phoenix Male connector with screw terminal adapter lets you connect speakers, while a 3.5mm jack port also enables headphone listening.
BERRYBAK HEV250 : HDMI 2.0 Audio Extractor and HDMI Splitter to 2x HDMI 4K 60Hz
In addition to its amplifier function, the Berrybak HEV250 acts as an HDMI 2.0 audio extractor and 4K 60Hz HDMI splitter. In fact, it features an HDMI input port for extracting sound from the signal and directing it to the speaker output, and two HDMI ports for recovering the video signal. The HEV250 supports HDMI2.0, HDMI2.0b, HDMI1.4, DVI1.0, HDCP2.3, HDCP2.2 and HDCP1.4, as well as 3D and HDR, 8/10/12-bit color depth, resolution up to 4Kx2K@60Hz and data rates up to 6 Gbps.
BERRYBAK HEV250 interface
Interface de contrôle du BERRYBVAK HEV250
BERRYBAK HEV250: simplified control with buttons and IR remote control capability
There are volume control buttons and a Bluetooth pairing button directly on the HEV250 case, plus an IR receiver module with a control learning circuit for pairing with an IR remote control.
BERRYBAK HEV250: USB-C power supply and USB-A charging port
The BerryBak HEV250's power supply is provided via a USB-C port accepting 20V 3-5A, and is compatible with PD adapters up to 100W. This enables the Berrybak HEV250 to reach a power of 2x40 @ 4 ohm (THD+N=10%). A USB-A port also lets you power an external device or recharge your phone, for example.
The HEV250 is supplied without a power supply. An AC adapter (Power Delivery) such as those offered as accessories is required for operation.
Port d'alimentation et de charge USB du BERRYBAK HEV250
Product typeBluetooth amplifier
HDMI extractor
Splitter HDMI to 2x HDMI
Amplification chipTAS5768 I2S AMP IC
Bluetooth chipQCC3034
Inputs1x HDMI
Bluetooth
Outputs1x Stereo speaker output (phoenix male terminal with phoenix female to screw terminal adapter)
1x 3.5mm jack
2x HDMI
Output power2x 36W @ 4 ohm (THD+N=1%)
2x 40W @ 4 ohm (THD+N=10%)
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD
HDMI compatibilityHDMI 2.0, HDMI 2.0b and HDMI 1.4
HDCP compatibilityHDCP 2.3, HDCP2.2, HDCP1.4
DATA rateUp to 6Gbps
HDMI video resolutionUp to 4Kx2K@60Hz, 3D and HDR, 8/10/12-bit color depth
SNRHDMI input: 104.71dB
Bluetooth input: 102.35dB
THD+NHDMI input: 0.028%
Bluetooth input: 0.013%
Additional functionIR receiver and control learning circuit (IR remote control not supplied)
Supply voltageMin : 12V
Typ. : 20V
Max : 24V
Dimensions103 x 100 x 34.5mm
Weight191g
Package1x BerryBak HEV250
1x HDMI cable
1x Phoenix female to screw terminal adapter
1x Bluetooth antenna
InputHDMI
OutputJack 3.5mm
OutputScrew terminals
OutputHDMI
OutputPhoenix connector
Channel2 (Stereo)
Amplifier chipTAS5768
Power (W)36.0
The BerryBak HEV250 is a versatile device designed to enhance your home theater listening experience. It integrates a TAS5768 I2S AMP IC amplifier...
