DAYTON AUDIO HTA20 Hybrid Tube Class AB Amplifier Bluetooth 2x15W 4 Ohm
The Dayton Audio HTA20 is the perfect solution for enjoying the warm sound of a tube amplifier. With its hybrid design, it combines the vintage sound of tube amplifiers with the modern convenience of semiconductor amplifiers. This allows for a unique blend of both vintage and modern technologies.
Reference : 17558
199,00 €tax incl.
165,83 € tax excl.
Last items in stock !
Shipping date: 27-05-2025.
Dayton Audio HTA20
Dayton Audio HTA20 Amplificateur à tubes hybride Bluetooth 2x15W 4Ω
The best of both worlds
Debate often rages over which of the tube amplifiers or the transistor models produces a better listening experience. The HTA20's hybrid design puts an end to this debate by utilizing the best of both worlds.. The amplifier thus uses both the classic design of a class AB architecture while employing tubes in the preamplification circuit.
Flexibility & Performance
With a power of 2x15W RMS under 4Ω, the HTA20 is ideal for the integration of a small or medium HiFi system. It also benefits from the convenience of Bluetooth 5.0 connectivity, allowing you to stream and control your music remotely, from a smartphone or tablet for example.
Versatile connectivity
With its two stereo RCA inputs and USB-B port, the Dayton Audio HTA20 is versatile, allowing it to connect to a wide range of source devices. In addition to its speaker terminals, the Dayton Audio HTA20 also features an RCA subwoofer output and a 6.35mm headphone output.
Product typeAmplifier
InputsBluetooth 5.0
1* USB-B
2* Stereo RCA
OutputsSpeaker terminals
1* RCA subwoofer output
1* Jack 6.35mm headphone output
Amplification typeClass AB
PreamplificationTubes
Tubes2* 6F1
Output power2x15W RMS @ 4Ω
THD< 0.5% @ 15W RMS
Minimum speaker impedance4Ω
Total gain28dB
SNR75dB
Frequency response20Hz-20kHz (1dB)
Input sensitivity315mV
Channel separation53dB
Supported sampling rates (USB)PCM up to 32bit 192kHz
Supported Bluetooth codecsSBC, AAC
Tension d'alimentation110-220VAC 50/60Hz
Consommation en veille8W
Dimensions279*165*216mm
Poids1.15kg
Package1* Dayton Audio HTA20
1* Câble d'alimentation
OutputSubwoofer
OutputJack 6.35mm
OutputSpeaker terminal
Channel2 (Stereo)
Channel2.1
ClassClass A / AB
Amplifier chipN/A
Power (W)15.0
The Dayton Audio HTA20 is the perfect solution for enjoying the warm sound of a tube amplifier. With its hybrid design, it combines the vintage...
