DAYTON AUDIO HTA200 Hybrid Tube Class AB Amplifier Bluetooth 2x70W 4 Ohm
The perfect solution for enjoying the warmth of a tube amplifier, the Dayton Audio HTA200 features a hybrid design, combining modernity and vintage. It combines the characteristic sound of vintage tube amplifiers with the modern convenience of solid state amplifiers.
By buying this product you get 54 loyalty points
Reference : 17561
549,90 €tax incl.
458,25 € tax excl.
Shipping date: 18-07-2025.
Grantie 5 ans
Dayton Audio HTA200
Dayton Audio HTA100 Amplificateur à tubes hybride Class AB Bluetooth 2x65W 4Ω
The best of both worlds
The debate often rages over whether tube or transistor amplifiers produce a better listening experience. The HTA200's hybrid design puts an end to this debate by exploiting the best of both worlds. The amplifier uses both the classic Class AB architecture design while employing tubes in the preamplifier circuitry.
Flexibility & Power
With a power of 2x70W RMS under 4Ω, the HTA200 offers a nice power reserve for the integration of a robust HiFi system. It also benefits from the convenience of Bluetooth 5.0 connectivity, allowing you to stream and control your music remotely, from a smartphone or tablet for example.
Versatile connectivity
With its RCA auxiliary input, phono input and USB-B, optical and coaxial digital inputs, the Dayton Audio HTA200 is versatile, allowing it to be connected to many source devices. In addition to its speaker terminals, the Dayton Audio HTA200 offers a subwoofer output on RCA and a headphone output in 6.35mm jack format.
Product typeAmplifier
InputsBluetooth 5.0
1* USB-B
1* Optical Toslink
1* Coaxial
1* Stereo RCA (AUX)
1* Stereo RCA (phono input)
OutputsSpeaker terminals
1* RCA subwoofer output
1* Jack 6.35mm headphone output
Amplification typeClass AB
PreamplificationTube
Tubes2* 13P1P
2* 6H2
2* 6A2
Output power2x70W RMS @ 4Ω
THD+N< 1.5% @ 70W RMS
Minimum speaker impedance4Ω
Total gain29dB
SNR80dB
Frequency response15Hz-20kHz (1dB)
Input sensitivity630mV
Channel separation53dB
Supported sampling rates (USB)PCM up to 32bit 192kHz
Tone control±6dB/oct @ 200Hz et 4000Hz
Supply voltage110V 60Hz
220V 50Hz
Standby consumption45W
Dimensions333*318*165mm
Weight7.44kg
Package1* Dayton Audio HTA200
1* Power cable
1* Bluetooth antenna
1* Remote control
InputPhono
OutputSpeaker terminal
OutputSubwoofer
OutputJack 6.35mm
Channel2 (Stereo)
Channel2.1
ClassClass A / AB
Amplifier chipN/A
Power (W)70.0
Remote ControlYes
The perfect solution for enjoying the warmth of a tube amplifier, the Dayton Audio HTA200 features a hybrid design, combining modernity and...
