13P1P Replacement Tube for Dayton Audio HTA200
This 13P1P vacuum tube is a direct replacement for the large (outer) tubes in the Dayton Audio HTA200 tube hybrid stereo amplifier.
Reference : 20761
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 24-11-2026.
13P1P Tube Tube de remplacement pour Dayton Audio HTA200
Photo du 13P1P
This 13P1P vacuum tube is a direct replacement for the large (outer) tubes in the Dayton Audio HTA200 tube hybrid stereo amplifier. It acts as a shunt regulator and helps maintain a constant output voltage with a higher temperature coefficient and less noise than its solid-state equivalent.
13P1P
Product typeTube
Number of pins7
Filament heating voltage (Vf)13V
Filament heating current (If)750±80mA
Condition d'utilisation
Anode voltage28V
Grid 2 voltage26V
Grid 1 voltage0V
Anode current42±10mA
Grid 2 current≤4mA
Output power≤220mW
Internal resistance1500 ohm
Slope7.5±1.5mA/V
Capacitance
Input capacitance (Grid)15.5±2.5pF
Ouput capacitance (Anode)10.5±2.5pF
Transition capacitance (Grille-Anode)≤2.5pF
Max. values
Maximum filament voltage14.3V
Minimum filament voltage11.7V
Maximum anode voltage110V
Grid 2 maximum voltage80V
Maximum anode power loss6W
Grid 2 maximum poxer loss1W
Max. voltage between cathode and filament100V
Weight0.2g
Dimensions90 x 34 mm
Package1x Tube 13P1P
Contacts number7
Tube typeN/A
